Question about Montgomery Ward Televison & Video
Have a montgomery wards tv model jsj12220 with original remote but skips from channel 36 to 97 how can I get the other channels to work
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
swampduck651
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Posted on Feb 05, 2008
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Posted on Mar 31, 2008
SOURCE: locked channels and No remote for Citizen (JCTV 1592)
I pressed some key on my remote accidently and thereon i have not been able to move to any other channel except adjusting the volume in this one...pls suggest...I do not know if this got locked..
Posted on Apr 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
Does anyone know the comcast remote code for a Montgomery Ward TV?
I suppose the correct code will depend the model of your Montgomery Ward TV, but ours worked using a Magnavox code (11454). Model # GNB 152 78A, manufactured in 1987, and YES, it still works!
Sep 17, 2011 | Televison & Video
Please program channel memory and all channels are unavailable I have fios so I only need channel 3
U still have the tv original remote?Yes,must used it to get into chanel 3.Because the manual buttons channels up and down on the tv bazel frame will skip channel 3.Only able get into channel 3 by manual channel buttons up or down only if it was save in the tv memory.Try website like Remotes.com to buy the tv original remote.
Jun 07, 2011 | Philips Magnavox 27MS343S 27" TV
I have a "Montgomery Ward
The remote it dead,usally the CPU chip it dead,because the CPU chip it control everythings on the remote.Try website like Remotes.com to buy an original tv remote.
Mar 21, 2011 | Televison & Video
The tv that i have is a old model and does not have a hook up for a dvd player so i bought a s video cord but i don't have the remote for the tv to switch it to video so do i have to buy a converter
Maybe. What tv do you have? Does it have any buttons on the tv itself (other than the power button)? (Some older TVs reached the "change source feature" by scrolling up (past all channels) or down (below channel) with the channel up/down buttons. Unfortunately if you can't reset the channel skip list from the TV itself, this may not work - if that source is currently skipped.)
You may be able to get a replacement of the original remote or a universal remote that has a compatible source/input button code. (This may take a higher end universal remote.) Try remotes.com for a direct substitute remote (search on the tv model without including the brand).
If neither of these suggestions work out, then you should consider the RF modulator (video to RF converter) and setting the TV to channel 3 or 4, as needed.
I hope this helps.
(if you provide the model, I'll check my pile of manuals to see if there was a channel down/up option for changing the source. I can also check if remotes.com has a compatible remote for you.)
Sep 17, 2010 | Video Game Consoles & Games
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
How do you program the montgomery ward model number jsj12248 televsion so that you get more channels?
Hi, jsj means it`s built by sharp, you need to auto-program the set, push menu on set or remote and look through the menu settings for either auto-program or add channels , gl, video-tek
May 17, 2009 | Televison & Video
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
144 people viewed this question
Top Montgomery Ward Televison & Video Experts
Electro Med Services...
Are you a Montgomery Ward Televison and Video Expert? Answer questions, earn points and help others
