Question about RCA TruFlat 27F520T 27" TV
I moved the tv from one room to the other, and the screen is now mostly green and purple. What happened? How do I fix it?
If you have anything plugged into the t.v. via a scart lead such as a freeview box then check the ends are pushed in properly as this can sometimes cause similar problems.
Posted on Jun 03, 2010
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
Color problems??
There doesn't happen to be a speaker nearby does there? I've seen this a lot with center channel surround sound speakers. It goes like this because of the magnet in the speaker. Try moving the speaker if there was one (or anything else near the TV that may have a magnetic field). Then, every time after you turn your tv on it should get slightly better thanks to the built-in degaussing coil in your tv. If not, find a TV/Appliance repair man near you, and he will have what's called a De-gausser and will probably charge around $30 to use it on your tv. You'll be watching 2D TV again in no-time!! ;-)
Jun 05, 2009 | Hitachi 43FDX01B TV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Hitachi C50-FD2000 Screen Distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jan 02, 2009 | Hitachi C50F200 50 in. Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony Trinitron KV - 36FS13 36" flatscreen
Hello MLD110368
I think, TV screen has white-balance failure thats why TV light blinks 5 times.
While living in Pakistan, I can't fix your TV there. In my point of view, it doesn't cost much and you should contact nearest Sony repair shop.
Apr 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Purple hue on bottom of screen
You may have placed something with magnets near the bottom of the TV screen. Magnets will distort the electron beam in their vicinity. Move whatever you have there!
"de- gaussing" is the process of de- magnetising the shadow mask in the tube, it occurs automatically at switchon.
If removing magnets/ relocating TV / switching on and off does not fix the problem, it's time for professional intervention.
Feb 10, 2008 | Philips Magnavox 27MS343S 27" TV
MY Samsung DLP TV Has Green/Purple Lines
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
