Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica Minolta bizhub 350 Error c0500
I'm getting error c0500 and I don't know how to bypass it. Fuser seem to be fine.
  • 1 more comment
  • Anonymous May 20, 2008
    konica minolta bizhub 350
    error c0500 apears after turning on the machine
  • Anonymous Mar 21, 2014
    32error C0500
  • Anonymous Jun 14, 2017
    HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
    Champion:
  • 214 Answers
Did you do a trouble reset ?
Posted on May 11, 2008
Error code konica minolta bizhub 350
Sir which is it the Bizhub 350 or the Di2010 to different ways to clear the C0500 code.
May 21, 2013 | Minolta Office Equipment & Supplies
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
The machine has the error code c0500. I need to know how to reset the error
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Need for Assestance
Fuser malfunction.
Power off/on while pressing Stop.
Not recommended without having been checked by a service technician since it could result in a fire.
Mar 01, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,379 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
