Computers & Internet Logo
Posted on Aug 11, 2017
I am using ScanSoft PDF Create! 5. I created a
I am using ScanSoft PDF Create! 5. I created a PDF as a printout from an Excel file containing images, and the PDF file created was 393KB. I ran the same procedure a second time only minutes later and the PDF file created is 5604KB. I changed none of the settings. The two PDF files appear to be identical in quality. I obviously want to keep file sizes small for emailing, etc. What is happening?
2 Related Answers
Anonymous
  • 407 Answers
  • Posted on May 22, 2009
SOURCE: I can no longer create 1 pdf file from mulitple files in acrobat 6.0 standard. I have to create a pdf for each file in word or excel and then open up acrobat and create 1 pdf file from multiple pdfs.
Have you tried appending to the document? this should give you the option to add multiple files to..
Anonymous
  • 77 Answers
  • Posted on May 06, 2010
SOURCE: I have Scansoft PDF Create!
You can downloaded advanced excel to pdf,it allow you to convert a lot files at the same time.
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
tip
PDF Converter
PDF Download converts the page all while retaining the page layout, fonts, images and hyperlinks on the page. Its support for HTML, XHTML and CSS-based pages ensures the creation of high-quality PDF files, which are ideal for archiving, printing, sharing and emailing like <a href="http://www.anypdftools.com/pdf-converter-for-mac.html">PDF converter Mac</a>. <br /> <b>1. Easy PDF</b> <br />This Converter is used to convert from PDF file to Doc file. It is independent application software that does not require the MS Word or the Acrobat Reader. This program allows you to convert PDF file into Word document with a high speed. You can convert batches of PDFs to Doc format at one time. It has user friendly interface that makes it easy for use. <br />Easy PDF has some salient features as follows: <br />a. It compresses the pdf file as per your requirement without making changes in content and layout. <br />b. You can either add or delete text or images from the resultant Word document. <br />c. It works well on all the platforms like Win98, Win 2000, Win XP and Windows 7. <br /> <b>2. ISTS Office PDF Converter</b> <br />This Converter can convert word file, excel sheet and image to PDF and can also create images from your existing PDF file without affecting the privacy and security of PDF files. <br /> <b>3. PDF Converter Elite</b> <br />If you want to get best result with low cost and high speed, then you can opt the PDF Converter Elite. Using this tool, you will able to convert and edit the existing PDF. Not only this, you can even create new PDF from the older one. It is different from others in some aspects like it helps in creating new PDF and edit them as well. You can extract the pictures and text from the PDF files and export to your desired file format like Word document, Excel sheet or Power point presentation. Moreover, you can create compatible PDF files that can be easily viewed. <br /> <b>4. PrimoPDF</b> <br />This Converter by Nitro PDF Software is a freeware and you can download it from the Nitro Pro Website and install in your computer system. With this, you can even create PDFs from any file format which you can use for printing, screening, use in ebook etc. <br /> <b>5. Cute PDF</b> <br />It is also a freeware that can supports both for 64-bit Windows XP ,and 32-bit and 64-bit Windows Vista. <br />
on Jun 23, 2011 • Computers & Internet
2helpful
5answers
How do you erase text from a pdf file?
Chances are you're using Acrobat Reader to read the PDF (portable document format) file.
You need Acrobat "Writer" (aka Distiller) to actually make changes to a PDF file, as the reader can only read the image file itself.
Create an excel file using VB6.0
Use PDF-in-a-box. Create your file in excell, embedd their given applet code in VB and it will automatically be importedas a PDF file using your excel template.....sodeep
Creating pdf not working
If you can't create a PDF file with the Adobe PDF printer, proceed to Try to create a PDF with the Acrobat Distiller application. Note: This method doesn't support advanced PDFMaker features, such as maintaining links and document structure. Open a Word document, and then choose File > Print.
Regards,
Will
1helpful
4answers
How to convert jpg to pdf file
IMPORT jpg file in pdf, that means create new PDF and then insert jpg. picture-s. Save your file and that's it. probably youll get that at adobe, so find their software, couse reader in for reading such files.
8answers
How to convert jpg to pdf file...
Start your graphics processing software ( for example google picasa or as im demonstrating mircrosoft pait.
2. Open a JPEG picture document
3. Select from main menu "File"->"Print"
4. Select Printer "Virtual PDF Printer"
5. If you need to adjust PDF generation options, click the "Property" button on the right
6. Click "OK"
7. A dialog will pop up, assign the folder and file name of the PDF document to be generated
let me know if this helps
Top ScanSoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
