Question about E-Machines eMachines Desktop PC
T6532 monitor screen faded
My T6532 monitor image suddenly looks over-exposed. Adjusting the screen settings - brightness, gamma, contrast - helped a little, but I'm concerned that the video card and/or power supply or worse may be dying. What should I do?
    Scholar:
  • 50 Answers
There are a lot of things that can cause this kind of problem. You might try swapping out the cable connecting the monitor if you have an extra, or if you're lucky and own another computer, you can try to use another monitor, or connect another tower to the monitor in question to see if another computer works better with it.
If you've determined that it's not the monitor or the cable, it's most likely going to be an issue with your graphics adapter. If you are not comfortable messing around with the interior of your machine, a shop could help you do further testing to see what needs to be done. Most likely, a new motherboard will be the solution, since your particular computer's graphics chipset resides on the motherboard itself.
As a final hint, I've seen a lot of Emachines with motherboard issues at my primary place of work. You might try contacting Emachines if the machine is less than a year old, since it would fall under manufacturer's warranty and you can get the board replaced for free.
Posted on Apr 09, 2008
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
When I try to install SP3 on my eMachine T6532, I get a Blue screen error during installation. How can I fix this?
This could possibly be a driver issue. Please disconnect all devices connected to the computer other than the mouse, keyboard and monitor during installation. If installation completes successfully, then you may reconnect the devices.
Dec 23, 2010 | eMachines T6532 PC Desktop
Monitor Brightness problem
it is still on warranty... check on service ... or you can try to download drivers .. or new chipset for your laptop..
or on startup hit f and chose last known good configuration thaht worked.
Dec 02, 2009 | Computers & Internet
Dell 1908s LCD monitor (new)
return the LCD to seller and ask for replacement. LCD colors should be even from top to bottom. test it with plain color as a background such as blue so you can easily see the faded portion.
Sep 04, 2009 | Computers & Internet
Outdoor photos are all over exposed and white. Video works fine.
set ur screen first .click one image 1st load on ur pc. see the screen and pc screen then set ur screen brightness and contrast of ur camera
Jun 17, 2009 | Mitsuba DV505 Digital Camera
Cannot change the brightness
to adjust brightness levels you might want to modify ONLY the brightness, contrast and gamma settings. Others might mess up your colors or god knows what. You can also set up the GPU's brightness settings by going to the gpu's control panel, usually opened by right clicking the desktop and selecting your video card's control panel option. Then adjust the brightness, contrast and gamma options to suit your needs. Hope that helps!
Jun 10, 2009 | Hannspree HW191D LCD Monitor
Lcd Screen has issues.
i dont know but i would think using the screen from a different computer would not be good.
im sorry but you will have to buy a new one. there is no way to make the fade stop.
Dec 31, 2008 | Toshiba Satellite A215-S7422 Notebook
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Out of focus monitor - 955DF
Edge-focus is notoriously tricky on flat-screen picture tubes. I have not found anything on adjusting the focus for this model. it seems to be a common problem, though it seems to be more of a sample-defect problem rather than a poor design; a replacement should be OK.
Apr 04, 2006 | Samsung SyncMaster 955 DF 19" CRT Monitor
E-Machines eMachines Desktop PC Logo
163 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
