I have Bosch WFK 2401 UC Washer and it will not drain, I dont know if something is clogged or the pump is broken?
    Genius:
  • 1,417 Answers
this simply mean that some of your material have gone to block the water flow out unit what you have to do is to bale out the water then remove the cloth that have block the pipe .
thank you and good luck.
Posted on Jun 03, 2010
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Bosch WFK 6030 manual
Please check this link, it will help you with the working operations and trouble shooting:
washing machine advice
Oct 29, 2011 | Bosch WFK 2401
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
May 30, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Drain/spin cycle want start
open the cover on the pump, lower left. Make sure machine is unplugged take your finger and fell inside the holethat goes toward the tub and see if there is a clog.
Dec 01, 2007 | Bosch WFK 2401
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
