Question about Mamiya Photography
Mamiya RZ67 Camera Older model.
Camera operates with dark slide in place- interlock does not work. Bad contacts? Bad back? Internal problems in body?
Battery is fresh and tests OK under load.
  • 22 Answers
Problem solved- The camera does not operate correctly unless the battery is in good condition, in place, and all the contacts are clean. In the RZ76 as opposed to the old RB models the components "talk" to each other: via electronic circuits. The back "tells" the camera bod if the dark slide ins in or out and whether the film is loaded or at the end of the roll. If the batter voltage is too low or the contacts are no clean and making full contact the body has no way of knowing the condition of the film backs and the interlocking mechanisms fail to work.
What I did was firstly test the battery under load and discovered that the cell was a bit low. It was a fresh battery but it is a good idea to turn the camera off after shooting in case the is a slight current draw when the camera is idle (?) . I replaced the battery and traced the voltages through the body to see if it was getting to some of the contacts such as the onces on the meter prism which has LEDs to be lighted. I also used an ohm meter to check out continuity- everything seemed to be in order. I then cleaned all the contacts including the battery terminals withl alcohol and made sure everything was dry and clean.
Now- everything works. The camera was turned off overnight and the battery has lost no voltage when tested under load..
This camera is equipped with RB lenses which have no electrical contacts and therefore the camera and lenses can't "communicate" so the meter will not work with theses older lenses.
Ed
Posted on Apr 10, 2008
Manual pdf
Try Retrevo Manuals.com
Nov 21, 2013 | Mamiya RZ67 50mm F4.5W Lens
Mac Won't Recognize Mamiya ZD Back
install the drivers for Mac operating system. Not windows;
Mar 16, 2008 | Mamiya RZ67 ProII Medium Format Camera
I just got a Mamiya rb67 on ebay and I cannot get the cocking release lever to move or the shutter for that matter. I didn't want to force anything. I have looked at the manuals on the web, but cannot...
Have you tried it without the back attached, or without a dark slide in the back? Many cameras have an interlock preventing the shutter from firing while the slide is in. If that doesn't work, remove the lense and try it all over again - many times on these model's the problem lies in the lense, not in the body.
If neither works, consult a tech. But, expect more in repairs than you probably paid for the camera since these things are going for well under $300 these days.
Jul 26, 2011 | Mamiya RB67 Pro SD Medium Format Camera
Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Jan 09, 2011 | Mamiya 645 Pro TL Medium Format Camera
I have a mamiya RZ Pro two and I am looking to find a digital back for it. If you could offer any guidance and advice I would be very greatful as there seems to be very little help for th RZ film...
Currently . You need a digital back adapter (approx.$1500.00+ US) then the digital back itself (Approx. 25,000+ US). yes that is correct!. THe RZ67 Pro II needs the DM56 adaptor then the DM 56 back itself. Why not check out the all new RZ22 (22mp) or the RZ33(33mp). The RZ22 is approximately $12,000.00 US and the RZ33 around $18,000.00. Hasselblad also make a 39 and a 50mp digital medium format, expect to pay 2-3 times that of a Mamiya. For a 35mm type dSLR, Nikon just introduce the D3X with 24.5 megapixals. The body alone runs anywhere from $6,500-$8000 US.
Sep 12, 2010 | Mamiya RZ67 ProII Medium Format Camera
RZ67 with new battery, lens set, 120 film back set but we get all the time a yellow led warning and the shutter does not work
A yellow led indicates the wind lever isn't cocked, or a weak spring hasn't returned it to the fully up position. A red led says pull out the dark slide.
Oct 16, 2009 | Mamiya RZ67 ProII Medium Format Camera
My Mamiya RZ67II can not power up. Because I left the battery in the camera for about a year. Is that easy to fix ?
Damaged the gear which is mounted at bottom of focasing knob, ni problem if it removed only fine focas is not work.
Aug 31, 2009 | Mamiya RZ67 ProII Medium Format Camera
Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Mamyia rz 67 pro II
I've got the same problem :-( Help would be appreciated.
Apr 03, 2008 | Mamiya Photography
Open Questions:
Photography Logo
157 people viewed this question
Top Mamiya Photography Experts
Tony
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
