Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
I have a Craftsman 21 hp, 42" riding mower ~ 10 years old...when trying to start it, it just makes a loud metal noise like the gears are stripped. I'm going to try to remove the starter tonight...will I be able to see the gears without getting into the engine?
  • 27 Answers
Depends on the engine, briggs L-head opposed twins can be viewed by removing the sheet metal head cover near the starter, changing its starter is fun, as one of the bolts is under the flywheel, it can be changed without flywheel removal, with patience. Briggs Vanguard and Intek twins starters are easier to remove, the intek cowling has to be removed to see anything with starter in place but the starter can be removed with the cowling in place, the Vanguard has a few sheet metal covers that must be removed. If you've got a Kohler, starter removal is usually pretty straightforward, take the starter to a local repair shop for a comparison or test if you are unable to determine what's wrong. A decent shop will at least inspect it and show you what a known good starter drive looks like.
Posted on Jun 04, 2010
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
2007 craftsman sy 4500 42" mower will not climb small incline. any suggestions?
sign of a failing hydrostatic tranny. however 3 years is pretty quick for a transmission unless mower was used commercially. make sure your drive belt is snug.
Aug 26, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
19.5 hp 917270810 starter making loud squeel
remove a plastic cover above or near the starter to access the gear and check the teeth on the gear.\
if it is chewed up replace gear or the complete top of starter assemly consisting of a clutch a gear and fastening components.
Starter will have to be removed to do this.
check the flywheel gear also to be sure its teeth are in good shape.
if gear is good move motor off of compression stroke and try again
Jun 14, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
400 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
