Question about Toro Lawn Mower With Toro Power Tools
22 in persoal pace 195 cc Tecumseh oil leaks onto
22 in personal pace 195 cc Tecumseh oil leaks onto deck from valve side of engine - drips off cooling fin closest to crankcase. It is not the fill tube, no oil visible on cyl casing on fill tube side. all bolts snug. Leaks badly over 50 mins - from top of fill mark to below bottom mark. Is not burning - just leaking.
  • klyork19 Jun 04, 2010
    Sounds like a possibility. Is there a link to a diagram that shows me exactly where this vent is and if there is a part involved? I guess I have to take off the shroud and flywheel to service it? Also, is there some what to visually inspect this without tearing it partly down?
  • 420 Answers
There is a crankcase vent on top that may be cracked or out of place causing the oil to leak or the upper crankshaft seal may be leaking.
Posted on Jun 04, 2010
  • Mike Squire Jun 04, 2010
    You will be able to tell as soon as you get the rewind cover off, the vent is a tube that runs from the engine to the carburetor.
    New Friend:
  • 12 Answers
I have the same problem. Turns out that the crankcase gasket was seated wrong and kinked (it was a refurb engine). So it was leaking all the oil out the front and into the cooling fins.
Posted on Jul 10, 2014
  • Yumi Tak
    Yumi Tak Aug 27, 2014
    After taking the motor apart, I replaced it with gasket from Kiddie Boutiques on eBay. They have the cheapest prices for the gasket. The system has no leaks. I also checked to see if it was from the carburetor manifold. But in doing so I tore the gasket during removal. I had to replace it with a new one from Kiddie Boutiques. Part number 37609 and 36786. Works great.
What would leak oil onto the starter
the oil leak could be a bad valve cover gasket needing replacement, a head gasket leaking oil, a leaking intake gasket and oil running down along the engine block and dripping. it could be an oil pressure switch that is leaking. it is near the starter while driving or engine running can spray oil onto the starter. unless the oil leak is very bad and has been leaking a long time onto the starter will not cause it to act like a dead battery even then not likely. have a starter draw test down to check condition of the starter.
Sep 23, 2014 | 2003 Ford Taurus
Oil leaking around valve box & head on 12 h.p. tecumseh engine
Have you tried tightening the bolts up, engines produce crankcase pressure, it could be this causing the oil to leak
Sep 20, 2012 | Craftsman Garden
I have a 1998 dodge stratus. 2.4 L 4 cyl engine. smoke began coming from the back aarea of engine just in front of dashboard; radiator full. not running hot. oil level ok. no leak. no light indicato
Could be oil dripping from the valve cover onto the exhaust pipe.
One drip can cause alot of smoke when it hits the pipe.
Could be power steering fluid too.
Sep 08, 2012 | Dodge Cars & Trucks
Breather leaking oil
Usually this is caused by either crankcase over filled with oil, or head gaskt blown can also cause this. recheck your oil level and go from there
Dec 12, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Under load my tecumseh 6.25 lawnmower engin leaks out all over the deck ???what can I do to solve this???
Did you over fill the engine with oil?Some times the seal where you put oil in the engine is bad.You should be able to see where its coming from.
Aug 24, 2011 | Sears Garden
I have a 22" self propelled toro recycler, never
did u turn it on its side? change the air filter. change the plug. turning it on its side could cause a fouling in the plug or air filter to fill up with oil and shoot out on the deck. Use Stabil in the gas in the off season.
Apr 28, 2011 | Toro Garden
We have Tecumseh TSH 359/22272/81 motor on a Stiga snowblower. It did start and work but blew most of the oil out. Now it wont start. Where can I find new motor or parts, motor seems to have two axels...
Hi and welcome to FixYa. I am Kelly.
The fact that the engine blew out most of the oil during normal operation is an indication that there is a problem with the crankcase breather. You can usually resolve this by removing the breather from the side of the engine at the base of the valves and cleaning it with engine degreaser and carb cleaner. What I think happened was there was a bit of condensation in your breather and it FROZE in the closed position forcing the crank case to over-pressurize and porting the oil into the breather.
If by chance you over-serviced the engine oil before the last operation it will present the symptom you describe. Also if you tipped the unit more than 30 degrees.
It most likely will not start now from an oil fouled plug.
You can use this manual for locating "How to" repair your engine:
http://www.cpdonline.com/692509.pdf
Here is what the service manual says on page 82.
BREATHER PASSING OIL
1. Check the oil level, make sure the engine is not overfilled. Also verify that the viscosity rating on the container of
the oil being used is to specification.
2. Check the angle of operation. Avoid prolonged use at a severe angle.
3. Check the engine R.P.M. setting for excessive R.P.M. using a vibratach or other tachometer and compare it to the
R.P.M. settings found on microfiche card # 30 according to the engine model and specification number. Adjust the
high and low R.P.M. as necessary.
4. Check for leaking or damaged gaskets, seals, or "O"-rings. External leaks may not be evident; however, the leak
may prevent the engine from achieving a partial crankcase vacuum.
5. Check the breather for damage, dirty condition, or improper installation. The oil return hole(s) must face down.
6. Check the engine compression using a compression tester. If the engine has weak compression, determine the
cause of weak compression: worn rings, leaking head gasket, or leaking valves. Follow the compression tester's
procedure.
I can help more... the engine number you passed did not cross.
Thanks for choosing FixYa,
Kelly
Jan 25, 2011 | Tecumseh Snowblower Snow Blower Starter...
Smoke coming from the left side of the engine
this may be due to an oil leak getting onto the manifold or the manifold is cracked and exhaust gas is building up in the engine.
if smoke is intence and black this indicates oil.
if it is mid and grey blue this indicates exhaust gas
get checked by a mechanic
i hope this was useful.
Jan 24, 2011 | 2006 Chevrolet Blazer
Oil leak. Burning oil and leaving spots on the ground. Bad burning smell form the oil. Cant see any source from below.
If this is one of the front wheel drive v-8 models, there is a problem with the rear engine seals on some years. The seals open when the engine is hot and allow oil to drip. As the engine cools, the seals rejoin so the leak hides. Sometimes, all it takes is to retorque the existing sealing surfaces.
It may also be valve cover gaskets. The fan and motion of the car will cause these to run the dripping oil along to the rear of the motor like a rain gutter, then onto the exhaust and ground.
Nov 28, 2010 | 2001 Cadillac DeVille
Toro Lawn Mower With Toro Power Tools Logo
1,430 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
