Question about Dell SE198WFP LCD Monitor
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
I have a Dell SE198WFP Flat Panel Monitor and the screen goes black every few seconds. I'll shut the monitor on and off and can then see my screen for a few seconds before it goes black again.
Can't figure out if it's a virus, monitor, driver, or computer problem?
Can anyone help me, I'm a transcriptionist who works at home?
    Guru:
  • 592 Answers
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Posted on Jun 03, 2010
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
My monitor is a dell 2000 flat screen 20.1" turns
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Dell LCD screen - powers up...i see the log on then black
I guess your monitor needs some maintenance.
Have it checked by a technician
Mar 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
White Screen
sounds like a faulty monitor,time for a new one,is it under warantee???
Aug 16, 2009 | Dell SE198WFP LCD Monitor
MONITOR COMES ON FINE I GET A FLICKER AND THE SCREEN GOES BLACK
It’s very likely your monitor has failed. Most Dell monitors have a 3 year warranty, so if you got it before three years, you could get it replaced by calling Dell. If you got the monitor with the computer, you can check your warranty online from with your computer Service Tag from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen . If you bought the monitor separately, you would need an Order Number or Customer Number for the purchase, or you could call Dell support and they could pull it out with your registered phone number. Dell would also need the serial number (starting with CN XXX..) from the back of the monitor.
Monitor User guide for SE198WFP available at http://support.dell.com/support/edocs/monitors/SE198WFP/en/preface.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell SE198WFP LCD Monitor
MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
Dec 29, 2008 | Dell SE198WFP LCD Monitor
Dell SE198WFP LCD Monitor Logo
1,160 people viewed this question
Alun Cox
