Open the hopper unit at the front of the copier and unclip the waste toner bottle ... you will see a picture with two lock one in the open position and the other closed.... below that you will see a knob(which is actually the toner bottle now turn it to the unlock position and pull out straight..... now reverse the process to insert new toner bottle.
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
