Question about LG DLG5932W Gas Dryer
Not drying or turning just a humming sound - LG DLG5932W Gas Dryer
Humming noise
SOUNDS LIKE MOTOR GOING BAD OR SOMETHING IN THE HUB BEARING ASSEMBLY GOING BAD
Apr 22, 2014 | Frigidaire Dryers
Hum created by Denon AVR-3300
Look for bad electrolytic capacitors. Swollen up on top or leaking, puffed out on bottom. If they look alright, you will need a capacitor tester to see if any have dried up. That's the first thing I check for hum.
Jan 09, 2014 | Denon Audio Players & Recorders
Please HELP.... I have a Whirlpool Quiet Dry 1 Dryer, it's about three years old and just stopped working. I have had no problems with heating. When I turn the dial to a setting I hear a humming sound but...
ok ok ok,,,keep cool? try checking the drive motor it may have burn out or jamed up so wont be turning but it may be causing the humming sound you here,
Nov 28, 2010 | Dryers
Left rear speaker makes humming noise after A couple of hours
This sounds like a dry capacitor on the input / output audio circuit or a dry solder joint on the IC chip left output.
May 21, 2010 | Audio Players & Recorders
Today our dryer quit drying. It hums but is not tumbling.
Dryers are belt driven. Something has locked the drum or motor, and that is why you hear the humming sound. With the dryer turned off, reach inside the drum and try to turn it. It should turn pretty freely. There will always be some drag. If you need a lot of effort to turn the drum, then it is time to investigate what is causing the drag. Probably, something has gotten wedged between the drum and the front wall of the dryer.
If you cannot find anything there, then it could be helpful to remove the outer shell from the dryer and investigate further to find the source of the drag. This requires some mechanical skill, so think carefully if you want to try it or call a service company or simply replace the dryer. A used dryer can cost $100 or less.
Feb 16, 2010 | Maytag Dryers
Should the an on my master 150000 btu be hard to spin . My wont run all of a sudden. It keeps tripping the reset button aftera humming sound for a few seconds
the fan should turn freely. those fans have a tendancy to dry out and will trip the reset. if the fan isn't shot completely, try oiling it and working the blades until they loosen up. most of the fans used on these units are not bearing type but brass collars which dry out. if they don't loosen up, the fan is probably too far gone. usually the humming indicates the motor trying to turn the rotor but can't turn the dry rotor shaft or a bent blade stuck on something. good luck jay
Jan 04, 2010 | All-Pro Forced Air Kerosene Space Heater...
Ran out of gas and now wont start
Have someone turn the key on (engine off) pull gas cap and listen at the fuel tank filler tube for a humming sound for a few seconds fuel pump running,If you don't hear a humming noise check fuel pump fuses,if you hear pump running it is a good possibilty that the pump impeller broke from running dry and you will have to replace fuel pump.
Nov 15, 2009 | 2001 GMC Yukon XL
Have sound, but humming noise is in background
Your audio codec might not be updated. Try installing audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Oct 18, 2008 | Harman Kardon HK595 Computer Speakers
LG DLG5932W Gas Dryer Logo
47 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
