Question about Dometic Rooftop RV Air Conditioner
My roof top a/c cools , but have 58-60 deg at regester , out side temp is 78-80 , temp at condensor is 105-110 , temp slector on coldest, fan on hi. how do install r22 in suction side , with no fitting . spect for r22 16oz
  • 674 Answers
If there is no fitting then you can get a line tap valve that clamps on the refrigerant line so that you can connect guages. However, to buy R22 you have to have an EPA CFC certification card. This ensures you have training on the proper handling of refrigerants which can damage the O-zone. I know this isn't much help but that is the way it is. I far as I know the only thing you can get without the card is R134a which won't do you any good.
Posted on Jun 03, 2010
I have 2 Coleman roof ac's on my 34' coach that are ducted. The fans work and the compressors come on but the air isn't cold enough to cool the coach. The front unit temp only goes to 70 deg....
Are there any filters? If they are clogged the unit will not work properly and the temp will not drop as much as it should as it cannot absorb the air in the trailer or room.
Aug 02, 2011 | Coleman Mach 15 Air Conditioner
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
Dometic Rooftop RV Air Conditioner Logo
100 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
