THE CHARGING 9V INPUT IS GONE INSIDE SMARTBOOK I
THE CHARGING 9V INPUT IS GONE,AND IS INSIDE MY SMARTBOOK , I COULD HEAR IT BOUNCING AROUND.HOW CAN I GET IT OUT?
    Guru:
  • 592 Answers
You will need to take this to a service center. The only way the "get it out" is to dismantle the unit and remove the broken peice and have it replaced.
Posted on Jun 03, 2010
Testimonial: "THANK YOU I WAS TRYING TO OPEN IT MYSELF AND PUT BACK WHERE IT BELONGS BUT YOUR RIGHT IM BETTER TAKING IT TO A SERVICE CENTER"
    Problem Solver:
  • 15 Answers
You should take the Laptop to a Certited Technician if you dont know how to soder then you will not be able to fix this problem, The Input needs to be resodered to the MB and I would take the Laptop to someone that knows what they are doing otherwise you will end up with a worthless Box of parts.You can remove the screws with the correct tools, But Like I said you better know your way around the repairs.
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
Digitalgadgets
Please describe the procedure you have gone through to connect so far with any error messages. Please also include the OS installed on the Smartbook.
Apr 23, 2013 | Sylvania Wireless Smartbook - SYNET07WICV
The speedometer in my 1999 Ford Expedition keeps bouncing I was told it was bouncing around because I got a new battery and my altenator was not properly charging it. . .is that true?
I never heard this, but it may be a bad speedometer sensor(which is located on the transmission). If the alternator is not charging, try this. Turn on your truck and while it's running remove the ground battery cable, if it dies on you, then you need a new alternator, if not then your alternator is working like it's suppose to.
Jul 12, 2011 | 1999 Ford Expedition
I just bought my smartbook today. When I plugged it in to charge... the red light comes on indicating that it is charging for no longer than a couple of minutes before turning off. Also, when I try to...
I would not attempt any repairs, return this if it is under warranty, there is a fault with the battery, the charger, or the charging/power circuit
Jun 16, 2011 | Sylvania G-Netbook
Nokia 3110c Charger not supported
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2010 | Nokia 3110 Cellular Phone
I hear air sounds in the top of my filter how do I get the air out?
It should eventually purge just by running. If it continues, you could have a suction leak in your piping. Check drain plugs in pump. Check strainer basket cover and gasket for leaks. Check any control valves for leaks, Check the multiport valves for leaks. If the basket was ever out of the pump, some item may be bouncing around inside also.
Aug 05, 2010 | Hayward SAND FILTER, PRO SERIES
Wont start
If the battery is hot, it possible that there is a short internally or the battery has been overcharged. A battery will get hot normally just from engine heat and electrons bouncing around to create the electricity inside the battery. First start with having the battery tested and then the charging system when the engine is running. Let me know what you find and if you need further assistance.
May 11, 2010 | 2001 Land Rover Discovery Series II
Power cord
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
The power cord is
Input: 120V, 60 Hz.
Output: 9V AC, 400 mA.
So , there is no need to worry about Polarity here. Just make sure , the output voltage is around 9V. DC input is ok. since there is bridge rectifier inside.
Aug 17, 2008 | AT&T 1717 Digital Answering Machine
Vtech DECT 6.0
get a multi meter and test the charging unit for 9v. if the transformer output to batteries is other than the 9.6, you will see that output.
it will say right on the transformer what the ouput should be.
it has to be at least what the output of what the battery is.
if it's not you'll need a new transformer.
i've seen this before where the battery output is 9v but the charger is only producing a limited out of around 3v.
Jan 14, 2008 | GE 28112EE2 Cordless Phone
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
