Question about Imation MT2028DBLK 20 inch TV
Will not turn on
My television was on and it just went out. The red light that signals standby is not on either. The remote control will not turn the tv on either.
    Scholar:
  • 121 Answers
Without even a standby light on, it means that there's no power being fed into/out of the power supply. If it's an external power supply (a little, or large, black rectangle attached to the power cord) then it can be easily opened and checked for blown fuses. If it's just a blown fuse, then that can be replaced for less than a dollar in most situations.
Posted on Jun 03, 2010
Hitaci plasma 42hdt20 remote will turn monater when red standby light on
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Dec 25, 2016 | Hitachi 42HDT20 42 in. Plasma Television
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
Oct 16, 2015 | Sony KDL46EX400 46 in. HD-Ready TV
Television is on standby-red light is flickering but the set will not turn on
The power supply needs to be repaired or replace the Module.
Nov 01, 2012 | Televison & Video
I don't have s stanadard TV set (CRT) with pre-digital tuner. I have a Sony PVM-2950 (2950Q) CRT monitor (no TV signal tuner, dumb tube). It accepts external signal feed. Today, the red...
Hello. You might try to re solder the power supply and deflection area, Also the common problems of this TV are the capacitors that lose value. But I think you have loose connections on the card. Good luck, if you have any questions, I'm here to help you with more details. thanks
Aug 14, 2011 | Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
My Olevia 27in. LCD Television does not turn on
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Red light is not on and the remote will not work
If you have no indicator light on the TV at all, the first place to look will be the power supply, if you do have light, then at least the 5v standby power supply is working which supplys the power to the controller board, when it receive the ON command from the remote or from the power button, the controller board will send out the ON signal to the main power supply section to supply the power to the rest of the circuit. So 5v standby voltage is a must. You may have bad capacitors in the power supply.
Nov 09, 2009 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Remote control set up code
Try searching for the code
To search for your television code:
1. Switch your television on (not in standby).
2. Press and hold down MAGIC until the ONE FOR ALL
1 red light blinks twice (the red light will blink once
then twice).
3. Press 9 9 1. The red light will blink twice.
4. Next, press POWER.
5. Aim the ONE FOR ALL 1 at your Television. Now press
CH+ over and over, until your Television turns off
(every time you press the CH+ key the ONE FOR ALL 1
will send out a POWER signal from the next code
contained in the memory). You may have to press
this key many times (up to 150 times) so please
be patient.
If you skip past a code, you can go to the previous
code(s) by pressing the CH- key. Remember to keep
pointing the ONE FOR ALL 1 at your Television while
pressing this key.
6. As soon as your television
Aug 21, 2008 | Televison & Video
Problems with Jwin JV-DTV30 30 in. HDTV-Ready LCD Television
This sounds like micro glitch try unpluging the tv and all controlable inputs (PC, iLinks, or other such devices) wait 5 min then plug the tv only in and see if you have returned functions. if you should read the manuals of those devices to see if the control functions can be turned off.
Jan 07, 2008 | Jwin JV-DTV30 30 in. HDTV-Ready LCD...
Imation MT2028DBLK 20 inch TV Logo
53 people viewed this question
Top Imation Televison & Video Experts
Electro Med Services...
Are you an Imation Televison and Video Expert? Answer questions, earn points and help others
