Question about Ricoh AC205 All-In-One Laser Printer
Get "open heat error" after one copy. tried unplugging
  • Ricoh Master
  • 525 Answers
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
  • Anonymous Jan 21, 2011
Samsung Printer SCX 4300 message "Open Heat Error"
on printer, in menu there is clear setting, find it and do ""clear setting" , "all setting", then will be fine
May 29, 2011 | Samsung SCX-4300 Monochrome Laser...
Open heat errors
Clean thermistor of dirt or Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Jul 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Open Heat Error
The fuser unit is most probably faulty, you will need to have it replaced.
May 19, 2009 | Samsung SCX-4100 All-In-One Laser Printer
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Open heat error
You have a fuser error. Unplug the machine and try again. If you still get the error, then you'll need to replace it.
Apr 20, 2009 | Ricoh AC205 All-In-One Laser Printer
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Open heat error on gestetner printer/copy/fax machine
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Aug 01, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Open heat error
Most "Open Heat Error" messages are caused by a bad fuser. Order a new fuser from Dell.
May 22, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Ricoh AC205 All-In-One Laser Printer Logo
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
