Question about Kitchen Ranges
I have an exhaust hood in my kitchen that is not working so well anymore. I have tried to replace and tighten the fan belt and it has gone through its semi-annual cleaning. There is no noticable obstructions, and even with the filters removed it just doesn't seem to be drawing the smoke through.
    President:
  • 1,561 Answers
The problem you posted seems not to be clear enough for me to suggest a solution to it, i will need more clarification on the question, in other for me to suggest a solution to the problem.
Please shed more light on the question.
Thank you.
Posted on Jun 20, 2010
How to replace head gasket on 4 cylander
2.6L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Negative battery cable
    • Hood
    • Accessory drive belts
    • Accelerator cable
    • Positive Crankcase Ventilation (PCV) valve and hose
    • Air intake duct
    • Fuel pressure regulator vacuum line
    • Canister hose
    • Brake booster vacuum line
    • Engine wiring harness connectors at right wheel housing
    • Ground cable connector at the intake manifold, starter and firewall
    • Heated Oxygen (HO2S) sensor connector
    • Alternator wiring connectors
    • Oil pressure switch connector
    • Starter motor harness connectors
    • Ignition coil connector
    • Spark plug wires
    • Distributor
    • Exhaust front pipe
    • Exhaust Gas Recirculation (EGR) gas temperature sensor connector
    • Air pump
    • EGR pipe
    • Heat shield
    • Exhaust manifold
    • Throttle Position (TP) switch connector
    • Cooling fan
    • Water pump pulley
    • Power steering pump
    • Intake manifold
    • Crankshaft pulley
    • Front cover
    • Timing belt. Refer to the Timing Belt unit repair section.
    • Valve cover
    • Rocker arms
    • Camshaft
    • Cylinder head
Cylinder head bolt loosening sequence - 2.6L engine
  1. To install:
  2. NOTE: Refer to Section 1 of this manual for the cylinder head torque sequence illustration. The illustration is located after the Torque Specification Chart.
  3. NOTE: Lubricate the cylinder head bolts with clean engine oil for assembly.
  4. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows:
  5. Step 1: 58 ft. lbs. (75 Nm)
  6. Step 2: 72 ft. lbs. (98 Nm)
    1. Install or connect the following:
    2. Camshaft
    • Rocker arms
    • Valve cover
    • Timing belt
    • Front cover
    • Crankshaft pulley. Tighten the bolt to 87 ft. lbs. (128 Nm).
    • Intake manifold
    • Water pump pulley
    • Cooling fan
    • TP switch connector
    • Exhaust manifold
    • Heat shield
    • EGR pipe
    • Air pump
    • EGR gas temperature sensor connector
    • Distributor
    • Spark plug wires
    • HO2S sensor connector
    • Canister hose
    • Air intake duct
    • PCV valve and hose
    • Accelerator cable
    • Hood
    1. Fill the cooling system.
    2. Start the engine and check for leaks.
    Feb 05, 2011 | 1997 Isuzu Rodeo
    How do you replace?
    Kitchen hood replacement can be completed easily with a family member or a friend. While you may wonder why anyone would replace a kitchen hood, the answer usually is simple. Here is how to replace a kitchen hood.
    Tools Needed
    • New Range/Kitchen Hood
    • Screws
    • Screwdriver
    • Friend
    • Wiring Nuts
    • Circuit Tester
    Warning: Remember that you are dealing with electricity, so stay away from water and use all safety precautions issued by the manufacturer.
    Step 1 - Shut off Electricity
    Remember to turn off the electrical supply to the old kitchen hood. You will need to do this via the circuit breaker box. Wait for 10 to 20 minutes and then test the wires with the circuit tester to double check that no electricity is being supplied to the kitchen hood.
    Step 2 - Remove Old Hood
    After you know for a fact that it is not receiving an electrical current, you can begin the process of removing the older kitchen hood. You should first take off the electrical wiring cover that is located by the light fixture. Then have your family member or friend hold up the old kitchen hood while you remove any screws or bolts from it. Once that is done, you can then freely slide it off.
    Step 3 - Check Wiring
    Double check that you have at least 12 inches of wiring to connect your kitchen hood to the wall. It should be noted that if you have a kitchen hood without vents, proceed to step 5 next.
    Step 4 - Find the Ducts
    If your new kitchen hood has vents, you will need to locate the fan or vent duct. Once you have found it, you can open up the vent hole where it will belong.
    Step 5 - Wires
    Open up the covering for the wiring and put the covering in a safe area for easy reach.
    Step 6 - Install the New Kitchen Hood
    Have your friend or family member hold up the kitchen hood and mark the areas where the screws or bolts will be. Then have them put down the kitchen hood and screw in the screws half way into the holes. After that, you can slide in the kitchen hood.
    Step 7 - Route Wiring
    Lightly pull the wiring through the proper holes and connect both black wires from the new kitchen hood to the black wire from the wall with a wire nut. Then connect the two white wires from the hood with the white wire from the wall, again using a wire nut. Next, connect the green wire to the green ground screw. Then place the wire covering back on.
    Step 8 - Tighten Screws
    Finish tightening the screws in place.
    Step 9 - Test
    Check to make sure the fan and light work. If it is supposed to vent outside, make sure that the air is leaving the vent with no issues. If something does not work proper, repeat steps 6 and 7 until everything works well. Remember that you will be working with electrical equipment, so follow safety measures issued by the state or the city.
    Jan 29, 2011 | Kobe RA9436SQB Kitchen Hood
    Terrible noise when fan comes on...
    The fan is most likely hitting or scraping into something. Disconnect the power and open up the fan panel. Push the fan blade manually and see if it's hitting into any walls. If not it may be the vibrations from the motor. In this case you should tighten any bolts that aren't completely tightened
    Mar 13, 2010 | Zephyr Milano ZMLM90 Stainless Steel...
    The exhaust hood of my restaurant is very noisy. The problem started 2 months ago.
    I would first clean the hood throuoghly, and then check the bearing on the fan, also check if the fan blades are bent.
    Oct 08, 2009 | Kitchen Ranges
    I have a dayton kitchen exhaust blower mod no. 4hz65, 1/25 hp, 1550 rpm, 115 volts, 1.5 amps, 8 inches. it does not seem to do the job, do i need a stronger one?
    Remember air will only move as fast as the size of the exhaust pipe in relationship to the fans ability to push. Make sure yours is the proper size for the fans volume.
    Jul 07, 2009 | Dayton Exhaust Blower to vent your grow...
    Range master 50000 exhaust fan stopped working
    Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
    Jan 07, 2009 | Rangemaster Kitchen Hood
    Vent hood not exhausting properly
    you dont want to hear it but they are all the same.. the exaust fans down work to good. there isnt anything to do.
    Aug 24, 2008 | Kenmore 52153 Stainless Steel Kitchen Hood
    No suction
    There is a set of blocks that are installed on the venting system to make the unit recirculate....use the manual to find them and make sure your not venting half outside and half into the kitchen.
    Feb 02, 2008 | Zephyr Pyramid ZPY-E30S Kitchen Hood
    Kitchen Ranges Logo
    16 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
