Question about GE 30 In Freestanding Gas Range JGB290DENBB
Oven is not working. When I set the temp. it does
Oven is not working. GE profile model JGS968S0H4SS. When I set the temp. in any mode it does not heat up - no fire
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 03, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    On "bake" my GE profile
    make sure the display is correct put a thermometor in oven to get correct reading
    Mar 18, 2011 | GE Ovens
    Ge oven temp not correct after clean cycle
    What are you cooking pizza. When you get at the high extreme most oven controls are not as accurate and have a wider differential. I assume the measurements are taken without opening the oven.
    Dec 03, 2009 | GE Profile JTP56 Electric Double Oven
    GE Double oven flashing F2
    The f2 code means that the oven temp sencer needs to be replaced.
    Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
    Bottom oven doesn't heat after running self-clean cycle
    Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
    GE True Temp Profile Oven, Locked Door Light stuck on
    there should be some type of button that the door hits to turn it on and off
    Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
    GE mod.JDS27G0P2BG Oven Wont start
    You have a bad electronic control board.
    No repair.
    It must be replaced.
    Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
    GE Profile -Installed wall oven - won't heat
    brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
    Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
    GE 30 In Freestanding Gas Range  JGB290DENBB Logo
    315 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
