Question about Sony STR-DA3ES Receiver
Receiver misinterpreting IR signals
My Sony STR-DA3ES receiver began misbehaving several months ago. It seems to be misinterpreting IR signals from a variety of remotes, including its own, two different Sony DVD player remotes, a Samsung DirecTV receiver remote, etc. The result is the same; the STR-DA3ES switches input to Video 1. For example, I can press the "cursor" buttons on a DVD player remote to make menu selections on-screen, and at a seemingly random button press, the receiver's input will change to Video 1. In all other respects, the receiver is functioning normally.
I've dug around for any info about this problem and have found none. If there's any way to resolve this problem, I'd appreciate the help.
  • Grouchicarpo Apr 09, 2008
    Thank you for that info. At my own peril, I've disassembled the front of the receiver. :) The solder joints for the IR unit look clean, and the IR receiver itself (labeled IC101 on the board) does not appear to have any external damage or problem with its pins.
    I've looked around the board for components labeled similarly to C124. The only ones I see with soldered-in components are C122 - C125, which are all *under* the main LCD. So I can't get to them. Around the IR receiver itself are two spots without components labeled C109 and C110. The only other components around the IR unit are a couple of capacitors and the Power push button. However, since I'm not certain what the digital switch looks like, I could be overlooking it.
    Thanks again for the suggestions.
  • 4,234 Answers
There can be a few causes of this. Since it happens with a number of remotes, we can state that the problem is inside the receiver. In the front of the receiver (inside) you should see a small silver box. Inside that is the InfraRed receiver. This is a 3 pin device. Check to be sure that the pins have good solder joints. A bad joint can cause problems. Also, after the receiver comes what is called a digital switch. This is similar to a transistor except that it makes the transitions more steep, like a step rather than a ramp. If this part is bad you can get these results. The digital switch will be marked c124 (perhaps or somehting close).
Check these out and keep us posted.
Posted on Apr 09, 2008
DA 3ES powers on, shows the appropriate connections i.e. opt for directv playstation, etc , but has no sound for any sources. Several of the orange lights remain lit, audio split, and others and the...
Great testimony for those Monster surge protectors, huh?
Did the failure coincide with the storms? If so, stick a fork in it, it's done.
Just the same, if you really want an assessment as to damage and cost you need to have someone knowledgeable give it the sniff test in person.
No one out here can do that.
Mar 13, 2011 | Sony STR-DA3ES Receiver
Volume keeps going up by itself
you have a bad ground in the volume knob. first take the knob off and there should be a nut that tightens. tighten if loose. if not spray w-d 40 or any kind of penitrating oil on the nut and around it. it will not mess it up,ive done it several times. the worst it could do is not fix it.
Feb 10, 2011 | Sony STR-DA3ES Receiver
How can I connect a computer to the receiver
RCA to headphone jack lead is required, put RCA pins in amp and headphone pin in line out of computer.
Click here to see an image of subject lead / wire.
Jun 08, 2009 | Sony STR-DA3ES Receiver
Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Feb 08, 2009 | Sony STR-DE197 Receiver
Noise and popping on Sony STR-DA3ES
Sounds like its going to square wave clipping and poking a dc offset at your speakers. Happens when the amp reaches power supply ceilings. Pink noise such as "rain sound" will push the output stages and power supply to limits. If its on all channels, check power supply caps and check for dry solder joints. also look for that crappy brown hold down glue that goes conductive/corrosive. check all output stages particularly about discrete output devices that are attached to heat-sinks. They have a bad habit of dry jointing also. Good Luck
looked for a free manual on line for you got heaps... but not your exact model. You may be able to cross reference one
Feb 03, 2008 | Sony STR-DA3ES Receiver
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Jan 20, 2008 | Sony STR-DE845 Receiver
Remote Volume Control Not Working
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Jan 05, 2008 | Sony STR-DA3ES Receiver
Protector is flashing with the words under it saying"please power off" about 5 secs after I turn on my receiver
this happened to me.  one of the speaker wires had become unplugged and was touching another one... causing a short.  glad to know this unit is "smart" enought not to fry itself.
Oct 01, 2007 | Sony STR-DA3ES Receiver
Sony STR-DA3ES Receiver Logo
117 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
