Question about Motorola Walkie Talkies 2-Way Radio
Motorola T5950 led screen
I was pushing buttons on the radio and the led screen went blank. Is there a way to turn it back on? Thanks
  • Motorola Master
  • 1,641 Answers
Typically a blank screen indicates you are using a bad or defective battery. Try the battery of another radio in this unit and see if the problem still exists. There is no function to shut off the display screen, so it is apparent you have either a battery or radio problem. Here is a copy of the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf
Posted on Apr 08, 2009
My T5950 won't stop beeping when I push the PTT button. I tried holding the PTT in when I turn the unit on and that didn't stop it.
Very likely it is the battery. Beeping means not enough power especially when transmitting. Try charging the battery again, try transmitting again and plan on new batteries. They "wear out" even when not in use.
Oct 16, 2016 | Motorola Talkabout T5950 (7 Channels)...
How do i turn of the beep when keyed
Hold in the - button while turning the radio on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf
Best regards.
Aug 14, 2010 | Motorola Talkabout T5950 (7 Channels)...
My radio turn off after 1 minute in tx mode, how
If you are referring to when you hold down the PTT button for more than 60 sec. This function cannot be changed. It is self preservation of the final amplifier and other components in the radio. Transmitting longer than 60 seconds would damage/ruin the radio. (If this is not the issue please clarify.)
Best regards.
Feb 17, 2010 | Motorola Talkabout T5950 (7 Channels)...
I am using Motorola T5950 and have it set to Channel 7 with ICE to 4. Hunting buddies have Cobra Microtalks set to Channel 7 and ICE 04. I can hear them but they cannot hear me. Can I rectify this? Thanks
Check to see if your Qt filter is turned off. This is an extra filter the T5950 has to block out other users. It is possible you have yours turned on and it is blocking the cobras.
If it isn't the Qt filter, set all the radios to have their ICE in the off position (usually zero). The radios should then be able to communicate. It could be the ICE is slightly different between the brands.
Nov 13, 2009 | Motorola Walkie Talkies 2-Way Radio
Cant get the beep sound off when keying it
i helded the {+} at the same time i turned it on and it seems to take the beep off i guess will see if it happens agian , thank you for your help maybe i"ll be calling you again. kenstoy67.
Nov 15, 2008 | Motorola Talkabout T5950 (7 Channels)...
To stop the beep when keyed
Hold in the minus (-) button while turning on the radio will shut off beeps.
http://www.usersmanualguide.com/motorola/2-way_radio/t5950
T5950 2-way
Initially, pls check that the displays of both radios are identical. This is important to establish that the channel/frequency, Interference eliminator settings and all others are the same that both are paired. In some instances, the radio settings may not be changed if it is locked. Top unlock, press on the MENU button for about 3 seconds. For all other settings, pls refer to the user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Motorola Talkabout T5950 (7 Channels)...
Motorola t5950 two way raido
i do not have any experience with that model, however, i tried a cheap set a short while back, i noticed that if i tried to talk to the other portable while holding it, it would not work. i set the portable down and walked away from it, and it started to work.
maybe?
Feb 24, 2008 | Motorola Talkabout T5950 (7 Channels)...
Pair of radios won't talk to each other
Have you checked the QT filter? The T5950 have an addtional interference filter called the QT filter. It filters out other radios and allows Motorola radios to speak only to other Motorola radios with the filter. Check the QT setting on both radios by pushing the menu button 6 times, the QT setting will show. If it shows a straight line on the display the filter is not on. Now push the + button (beside the menu button), to turn the QT filter on (a Y will show on the screen when on) or the - button to turn it off (the line will show when filter is off). The radios have to match all channels and all filters to talk to each other.
Dec 09, 2007 | Motorola Talkabout T5950 (7 Channels)...
Motorola Walkie Talkies 2-Way Radio Logo
120 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
