Question about Lexmark X5150 All-In-One InkJet Printer
How do you unlock the scanner? My printer has been off for a while. When I turned it back on it make this clacking noise and I got the message, "unlock the scanner." How do I do this?
Open scanner until the red lever flops down. beside the lever on the left is a knob you squeeze and either pull or push depending on whether you are locking or unlocking it. Look through the glass screen and you'll it , there is a lock/unlock sign etched into the surface
Posted on Jul 15, 2010
WHILE THE PRINTER IS WARMING UP THE INK CARTRIDGE HOLDER WILL MOVE TO THE LEFT AND START TO MAKE A LOUD GRINDING NOISE. GET A MESSAGE TO TURN OFF AND CONSULT MANUAL. I DON'T HAVE A MANUEL. JOHN H
Hi!
On the scanner area look for a switch on the side or front that indicates lock position. You may need to lift the scanner up if you don't have the switch near the scanner bed. Make sure that switch is set top unlock. This is a feature for this type of printer to protect scanner part when transporting device.
Hope this helps.
Dec 13, 2010 | Epson Stylus RX580 InkJet Photo Printer
The error message is saying the scanner is locked i took the steps to unlock it but i still get the same message
If you opened the lid in the same manner as you would to replace the ink cartridges and made sure that the switch on the right side underneath the lid was in fact unlocked, turned off the unit, waited a moment (up to 60 seconds) and turned the unit back on, but still receive the message saying that your scanner is locked, then you will need to use a Phillips screwdriver to remove the top cover and make sure that the scanner head is not somehow jammed. Usually you can hear the gears and motor spin up when the scanner head is unlocked. If you cannot, you may have a bad scanner head.
Aug 03, 2010 | HP OfficeJet 9120 All-In-One InkJet...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
Jul 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Automatic document feeder does not work-- does not pick up paper
as soon as you load the original on the ADF you get the message as original loaded..check if you get this message..
if you do not get this message..try cleaning the rollers with the lint free cloth(dry cloth)..try to make a copy..if its still the same..
then connect the printer directly to the wall outlet..and then check..
if its still the same then try these steps..
1)unplug the power chord from the back of the printer..press and hold OK and CANCEL button together..
2)while pressing these two button plug in the power chord to the back of the printer..
3)after you plug in the power chord do not release those two buttons untill the screen goes blank..
4)once the screen is blank release the buttons and then turn on the printer..
5)then try to make a copy from the ADF..if its still the same..then machine should be replaced..
let me know if this has worked..
Mar 04, 2009 | HP OfficeJet 7410 All-In-One InkJet...
At the lcd screen you can read this message: "ESCANNER DESABILITADO"what should I do?
The scanner probably got accidently locked. Turn the machine off, unlock the scanner, then turn back on.
Instructions on how to unlock the scanner are found here:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=143,E=0000000001181477675,K=8219,Sxi=11,Case=obj(349)
Dec 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner error message hp laserjet 3030
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
