Question about Philips GOGEAR SA6045 MP3 Player
I've uninstalled go gear disc because of pc problems and now I'm unable to reinstall it because disc won't run.
  • 185 Answers
If your cd is not working go here and download the software, that will allow you to install without the cd.
if it works, don't forget to rate me
thx
Posted on Jun 03, 2010
Canon 495 won't print
Try going to the Control Panel and uninstalling the printer. **Make sure you have your printer install disc handy to reinstall BEFORE you uninstall the printer.
Then unplug the printer. Insert the disc and reinstall following the discs instructions.
Apr 03, 2013 | Canon PIXMA MP495 InkJet Printer
Acer external hard drive problem code 10
Try chkdsk or download Testdisk and run to ensure the disk is in good order.
Feb 27, 2013 | Acer Computers & Internet
I want to uninstall webroot and start over. I'm unable to remove aei.exe and other files. How can I accomplish this?
You may need to reinstall it to fully uninstall it. The uninstall may not have worked.
Have you turned off your computer since uninstalling Webroot? (Fully turned off, not hibernation mode) That may get rid of the running file.
To finish the job after uninstalling, simply delete the directory from the C: drive. (You may have to turn off and restart the computer before it will allow you to delete the folder.) A lot of programs that download updates on a regular basis will leave the updates on your hard drive even after an uninstall.
May 31, 2012 | Webroot Software Spy Sweeper with...
Internet not conect
If you are unable to connect to internet. There are few things you can try:
1) Reinstall the Ethernet drivers. Go to control panel> add/remove programs> uninstall the Intel or Realtek Ethernet drivers.Then reinstall the drivers from the motherboard disc provided with this pc. Make sure you install only the ethernet drivers.
2) If your pc is giving any kind of error message like limited connectivity then its a problem with your ISP(Internet service provider) or the windows operating system itself. Call your ISP and let them check the issue if they can't help go for a repair install of windows using the disc.
Hope that helps!
Sep 17, 2011 | Dell Dimension 4500 PC Desktop
I am unable to enable the bluetooth capabilities of my acer aspire 5745 laptop. I've reinstalled the driver from the driver disc and following the instruction of pressing the Fn+F3 keys together to...
After you uninstall the driver you might want to reboot then reinstall. Also make sure you have the correct drive 64bit - 32bit etc. could also be a button on your laptop my acer has one for enabling blue tooth. If that doesn't work also check in device mgr right click my computer or computer form the start menu then properties then device mgr right click on the blue tooth device and select enable.
Jul 19, 2011 | Computers & Internet
How do you uninstall a program from a palm treo 750?
You need activesync
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
ActiveSync’s Tools >Add/Remove Programs screen lists all the programs that have been installed on your device. To uninstall a program, uncheck the box next to it and click on OK. To reinstall a program, click on the empty box next to it and click on OK. Do not click on the Remove button. Here's how to do it: If you used ActiveSync to install a third-party program to your Windows Mobile device, you can uninstall the program quickly from your PC.
  1. Make sure your Windows Mobile device is connected to your PC and ActiveSync is running.
  2. From the PC’s ActiveSync Window, click on Tools >Add/Remove Programs. This opens the “Add/Remove Programs” dialog box, which displays a list of third-party programs you have installed on your device.
  3. To uninstall any of the checked programs, click on the box to uncheck it and hit OK—ActiveSync will do the rest.
Reinstalling programs you’ve uninstalled Once you’ve installed a program using ActiveSync, the necessary installation files are saved on your PC. If you uninstall the program as described above, you can use the Add/Remove Programs menu to reinstall it at a later time. Uninstalled programs appear in the Add/Remove Programs list as items with unchecked boxes. To reinstall it, click on the check box next to it and hit OK. ActiveSync will reinstall the program automatically. Note that files in CAB format can be downloaded directly to a device and installed, so they will not appear in the Add/Remove Programs list. In addition, some freeware programs are installed by using ActiveSync’s Explorer to copy the program file to your device. Those also do not appear in the Add/Remove list. WARNING: Do not click on the “Remove” button at the bottom of the Add/Remove Programs screen unless you never again plan on using the program. This completely removes the necessary installation files from your PC and you won’t be able to reinstall the program by checking the box.
Jan 08, 2010 | Palm Treo 750 Smartphone
DVDRWBB mechanic trouble
try uninstalling, turn off your pc, check the cables are connected properly then restart and let windows pick up the drive and reinstall the driver.
let me know how you get on so i can help you further if needed
Feb 11, 2009 | Dell Computers & Internet
USB not recognized
Call Net Gear Tech Support.
May 23, 2008 | Computers & Internet
Unable to access HP Photosmart
u change ur printer its simple
Dec 10, 2007 | Office Equipment & Supplies
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
