Question about Onkyo TX-SR607 Receiver
Onkyo TX-SR607 keeps turning off as soon as i turn it on
    President:
  • Onkyo Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
Had a power surge and now my Onkyo TX-SR607 will not power on. Only get a constant click sound. Any repair advice?
although power surge can trigger activations of protection circuits,
there are at times, damage is done before it is activated.
• Check first for low power supply regulators,
then check for possible output stage failure.
let me know if you need further assistance!
Sep 09, 2012 | Onkyo Tx-sr607 7.2-channel A/v Surround...
I lost manual to av receiver TX-SR607 can you help me? Can you send me a new manual plese.
if you go to onkyo website they have every manual for every piece of equipment they ever made. http://onkyousa.com/download/own_manuals.cfm?cat=Receiver go to the website and look for your model reciever.
Nov 16, 2011 | Onkyo TX-SR606 Receiver
My TX-SR607 Display is Lost but, Its still working. What happened...?
This can be due to failure of the display section power supply, the display processor or the display subsection circuit. So since the amp is working well otherwise then it is possible that voltage to the display is checked , the processor section is checked for correct clocking and the linking cords are checked. Sometimes it can be poor soldering joints and a good touch up of solder will solve.
Jul 16, 2011 | Onkyo TX-SR607 Receiver
TX-SR607 keeps turning ON then OFF by itself when not in used
Block the infrared eye on the front with something opaque or just shiled the whole thing from visual contact with the outside world and see if that stops. There may be another I/R transmitter somewhere in your environment. Dig the remote out from under the seat cushion so people will stop sitting on it. ;-)
Jul 13, 2011 | Onkyo TXSR607 7 Channels Receiver
We are having HDMI handshake problems between our Onkyo TX-SR607 and our Sony KDF-55WF655 LCD Projection TV. The problem is intermittant. Sometimes it comes up just fine, and other times the screen is...
Hello, I am sorry for your issue. Haw long is the HDMI cable from the receiver to the TV? Have you tried a different cable/ Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-SR607 Receiver
Lost colors when using composite cables with Wii
puedes subir o bajar la resolucion de tu t.v o pantalla ya que algunas son HDMI u otras FULL HD probablemente no este bien ajustada o los cables no estan funcionando bien o estan trozados,....
May 02, 2010 | Onkyo TX-SR607 Receiver
Powered sub only has sound while watching a dvd or listening to music on Onkyo TX-SR607
So perhaps it's a source sound issue. THAT would best be investigated at the Dish receiver. Consider it's audio settings and how it interfaces with the Onkyo.
Apr 25, 2010 | Onkyo TX-SR605 Receiver
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
No video output from Onkyo receiver
Hello, I am sorry about your issue. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 10, 2017 | Onkyo TX-SR607 Receiver
Onkyo TX-SR607 Receiver Logo
1,092 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
