Question about Samsung HP-T4254 42 in. Plasma Television
Video slowly degraded, at first, after being on a few minutes only the bottom half of the screen would be complete snow and after a while it would be good again. Then last week it changed to the entire screen, picture discernalble, but very bad. Now, the video is completely gone, no picture, some pixel action. Not sure if the Plasma goes bad like that or I have a malfunctioning video board?
  • dharding17 Jun 06, 2010
    The problem exists using both RCA and HDMI cables from different sources.
    Sniper:
  • 63 Answers
Your Y-Buffer Boards are going bad. There are 3 boards here. The Y-Buffer Upper controls the Displays top half, the Y-buffer Lower controls the Bottom half and the Y-SUS/Main controls those 2 boards. Usually when one goes they all go. The Boards are located on the far left of an opened set. They are the skinny boards going up and down. THey are connected directly to the Y-SUS on the right. However you can have good buffer boards and a bad YSUS. I have replaced the buffer boards on sets only to discover it wasn't those boards it was the YSUS
Posted on Jun 30, 2010
I REPAIRED A PLASMA OF THE SAME SERIES TO NOTICE THAT THE HDMI WAS VERY LOOSE
Posted on Jun 03, 2010
  • Anonymous Jun 07, 2010
    DO YOU HAVE A MULTIMETER AND ARE YOU ABLE TO CHECK VOLTAGES
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
Onkyo TX-SR604: Video in from cable box has taken increasingly longer to display a picture.
I would at least disconnect all units from power for a while and then reconnect to allow the units to reboot.
Oct 30, 2012 | Onkyo TX-SR604 Receiver
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Bottom half of screen black-out
I would replace the lower Y buffer. Part number 996500032640. Goodluck.
Jul 05, 2010 | Philips 42PF7220A 42 in. Plasma Television
Tv won't come one and blinks red 7 times then stops.
When the bottom half of the picture goes out this usually indicates a failure of the lower Y driver module. When this module fails it will often take out the Y sustain module and when that happens the set goes into over current shut down. Both boards will have to be replaced. All of this is assuming you have a Plasma set and not a LCD flat panel.
Jun 02, 2009 | Philips Televison & Video
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
White Internal Screen
ohh and my external screen is 2/3 working with a black stripe on the bottom
Nov 04, 2007 | Motorola Mobility E815
Samsung HP-T4254 42 in. Plasma Television Logo
186 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
