Question about Gaggenau EB294/295 Electric Double Oven
Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
I read Oshie's description of a problem found for this oven in that the bottom oven was not working. He stated that the proper main terminal jumper should be 'L'1-2-3 and 'N' 4-5. The display oven I recently purchased was jumper on delivery the same as this. Unfortunately, this unit did not include a schematic that showed wiring variants [ for US ] showing a proper 4-wire cable harness connection [ two dual phase 110V, 1 Neutral, 1 Ground] to the terminal. When my electrician went to install the unit, he was bothered by the live jumpers that would tie the two US 110V dual phase hot wires together in this factory jumpered configuration and would not make the connection. Gaggenau was no help in getting the proper wiring diagrams. Is the jumper configuration 1-2-3 tied for a European single phase 220 V application? If so, for the US 4 wire configuration, what would the terminal block to 4 wire cable harness wiring interface be?
Thank you in advance for your help in this matter,
watkinsm
  • 2 more comments
  • watkinsm Apr 09, 2008
    As stated in my problem ...this jumper configuration is a problem for United States 4-wire connections. what is the proper wire diagram with 2 110 live wires, a neutral and a ground wire to this terminal
    Is there anyone else that has an idea of how the US 4-wire cable harness should be wired to the Gaggenau EB294 double oven terminal block:
    that is L1,L2,N, and Gnd on cable to #1-6 on the internal oven terminal block. Or could get access and pass on the wiring diagram for this oven?
    I had accessed this manual before...it includes no wiring diagrams for how to hardwire this oven[ mine did NOT already come with a cable connection to the inner terminal block in the top of the unit ] to the household 4-wire connections. This connection is what I am trying to determine...especially since the terminal block comes strangely jumpered as I described with the 1-2-3 on the Mains 'L'.
  • Anonymous Mar 25, 2014
    how to wire standard US 220 to terminal block
    Master:
  • 788 Answers
Here's what the manual has:
8.2 How to do it
The appliance must only be connected by an
authorised specialist, paying attention to the
relevant regulations of the power supply companies
and the regional construction regulations.
The electrician is responsible for the correct
functioning of the appliance at the time of installation.
He must instruct the user on how to operate
the appliance correctly on the basis of the
Operating Instructions, and the user must be
instructed on how to disconnect the appliance
in an emergency.
We accept no liability for damage caused by failure
to comply with these instructions.
If it is not possible to disconnect the appliance
from the mains via an easily accessible plug and
permanent cable connection, an isolating switch
with a contact clearance of at least 3 mm must be
fitted on the installation side.
Repairs carried out improperly may involve
substantial risks for you.
Connection to the power mains
On the top of the appliance there is a cover that
has to be unscrewed. The wiring diagram stuck
onto the top of the appliance shows the connection
variant.
For 230 V / Connection with 3 N/400 V:
The oven is connected in three phases, i.e. L1, L2,
L3 and N. The power mains to which the oven is to
be connected is fused with 20 A in each phase.
For 230 V / Connection with 1 N:
The oven is connected in one phase, i.e. L1 and N.
The power mains to which the oven is to be
connected is fused with 40 A in each phase.
The appliance must be earthed.
The manufacturer cannot be held liable for
damages that might arise from improper or nonexistent
earthing of the appliance.
Screw the cover back on.
So the European single phase is L1 and N (4-5).
According to Gaggenayu these are the only two supported power supply connection methods. If I were you I would look into getting a 3 phase line put into your kitchen to be safe.
Posted on Apr 09, 2008
    Genius:
  • 3,422 Answers
Please click HERE to download the manual.Once you are at the site click on service and choose operating manual.
And if you still don't find what you need then please contact them they will forward you the service manual.
Goodluck,
please don't forget to rate the solution.
  • Priya darshan Apr 09, 2008
    Service phone:1-800-828-9165
    Service email: info@gaggenau-usa.com
  • 813 Answers
If its brand new, most possibly the electrician did not bridge the mains connection.
It sounds like an installation fault.
There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection.
Oshie
    President:
  • 2,267 Answers
If you have this user guide go to page # 40 for wiring instructions.
  • Jaime Hernandez Apr 09, 2008
    I do not think there are any wiring instructions except from the makes of this appliance.
    Have you contacted gaggenau's technical support?
Eb294 oven door removal
tip out till it stays open then lift the door off the hinges .
Mar 12, 2016 | Gaggenau EB294/295 Electric Double Oven
ALL POWER OUT HOT-AI9R OVEN EB 663-6
Check the breaker, sometimes they do not turn back on right. Flip it off again and then on really hard...
Also checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4502309-oven_repair_oven_will_not_work_all
heatman101
Apr 10, 2010 | Gaggenau EB294/295 Electric Double Oven
I have a gaggenau 194/195-610 Double oven that takes 25 minutes to preheat to 350%. Is there a quick diagnosis for this problem or do I need a repair service. These ovens have never really worked properly.
It could be a faulty stat or element, an engineer will be able to test them for you
Also he will make sure the cooker is wired properly at the cooker point (correct flex et.)
Sep 21, 2009 | Gaggenau EB294/295 Electric Double Oven
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Bottom oven door won't open
Started the pyrolysis cycle for 1 minute and then cancelled it. The door then unlocked.
May 25, 2008 | Gaggenau EB294/295 Electric Double Oven
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Code F14
F14 is usually the fault code (open circuit) for the NTC sensor on the electronics module. I would suspect a bad connection from the oven temp sensor (located at the rear of the oven) to the electronics module. If you are able to remove the oven from the enclosure and remove the top and rear panels, (power disconnected!!) I would suggest checking all connections to/from electronics module. Also make sure door contact switches are secure and not loose (remove side panels) Oshie
Mar 22, 2007 | Gaggenau EB294/295 Electric Double Oven
Bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
Gaggenau EB294/295 Electric Double Oven Logo
430 people viewed this question
Top Gaggenau Ovens Experts
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
