Question about Gladiator 19 cu. ft. Chillerator Garage Refrigerator
My refrigerator compartment is not cooling, but the freezer seems ok so far, at below zero temp. I thought the default is that both compartments are default freezer mode, and the upper compartment's temp is tempered with the dial in the back to make it a fridge. How can this be?
  • 17,970 Answers
You may be experiencing these problems because of a defective defrost timer, a defective defrost heater or a defective defrost thermostat.
1.- TES DEFROST TIMER
  1. Locate your defrost timer. It can be located behind the refrigerator's lower kickplate, in the refrigerator's control panel, or even behind the refrigerator on its back wall. Defrost timers almost always have four metallic terminals extending from the bottom. Once you have found your refrigerator's defrost timer, remove it for testing.
  2. A defrost timer is usually secured inside a refrigerator with at least one screw, but sometimes more. Remove all the screws you find and pull the timer carefully out of the refrigerator. Pull it out far enough so that you can disconnect its wires. Pull firmly on the wire's connectors to remove them. You may need to rock them back and forth a little to ease the motion. Don't worry about which way the connector comes out because there is only one way it can go back in.
  3. Use your multitester to test the timer for continuity. Set your multitester to the R X 1 scale. Place one of the tester's leads on the coommon terminal. It should be labeled "3" or "C". If none of the terminals are labeled, you can locate the common terminal by determining which terminal coincides with the white wire in the connector plug. With one multitester lead (probe) touching the common terminal, touch the other lead to the other three remaining terminals, one at a time. Testing the first pair should produce a reading of zero, or near zero, denoting continuity. The second pair may also result in a reading of zero or near zero. Testing the third pair of terminals should produce a reading of infinity.
  4. Find your refrigerator's timer switch and turn it in a clockwise motion until it clicks. Use your multitester and test the terminals again in the same manner as in the preceding paragraph. In this test, one of the pairs of terminals should produce a reading of continuity. At least one pair, but maybe two, should produce a reading of infinity. One important note to keep in mind is that a pair of terminals that demonstrated continuity in the first test should now demonstrate infinity. Likewise, a pair of terminals that demonstrated infinity in the first test should now demonstrate continuity.
  5. If the test you conduct with your defrost timer does not produce these results, then you should replace the mechaninsm.
2.- TEST DEFROST HEATER
  1. Locate your defrost heater. It can be located behind the back panel of the freezer section of your refrigerator, or under the floor of your refrigerator's freezer section. Defrost heaters are commonly located beneath a refrigerator's evaporator coils. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
  3. Defrost heaters are available in one of three primary types: exposed metal rod, metal rod covered with aluminum tape, or a wire coil inside a glass tube. Each of these three types is tested in exactly the same way.
  4. Before you can test your defrost heater, you have to remove it from your refrigerator. A defrost heater is connected by two wires, and the wires are connected with slip-on connectors. Firmly grasp these connectors and pull them off the terminals. You may need a pair of needle-nosed pliers to help you. Do not pull on the wires themselves.
  5. Use your multitester to test the heater for continuity. Set your multitester to the R X 1 scale. Place the tester's leads on one terminal each. This should produce a reading anywhere in between zero and infinity. If your multitester produces a reading of zero, or a reading of infinity, then your defrost heater should most definitely be replaced. There are many different kinds of elements, and so it is difficult to say what exactly the reading should be for your defrost heater. But it definitely should not be zero or infinity. If it is, replace the mechanism.
3.- TEST DEFROST THERMOSTAT
  1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
  4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
  5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
Tell us news.
Posted on Jun 03, 2010
Refrigerator
Most refrigerators have only one evaporator that handles both compartments. Only the very expensive ones have two evaporators that cool and independently control the temps separately.
Most simply circulate a small percentage of the cold air with a fan in the freezer section (where the thermostat that controls the compressor is getting its signal from) blowing over to the refrigerator section with the hope that that keeps things cool enough in the refrigerator section. If your LG is one of the common ones, it could be something a simple as a large object blocking the air flow between the two sections or a problem with the circulating fan. Also the dial that supposedly controls the temperature in the refrigerator compartment is sometimes connected to a linkage that determines how far a flapper door is help open or closed. Look for a problem in that linkage or damper door.
Aug 13, 2016 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
The refrigerator compartment not cooling, freezer is ok so far
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
469d
Jun 03, 2010 | Gladiator 19 cu. ft. Chillerator Garage...
Temp inside fridge is 46degrees. Besides
46 degrees is still below normal room temperature so it seems that the unit is cooling....you do not mention whether it is 46 degrees in both the freezer and the food compartments.....if the freezer is still cold...say below freezing or near zero but it is hot (46) in the other part of the refrigerator then there are probably 2 possibilities:
1. The small fan inside the freezer may be stuck and not spinning...they seem to go bad or at least stop spinning regularly on many freezer compartments. For most designs the fan must be running to circulate the cold air inside the freezer and also send some of the cold air over to the normal food compartment. When these fans shaft get stuck they will often emit a high pitched noise if they are able to turn at all. Of course if not turning t all then there is no sound. Determine if the fan is working....if not you will probably need to replace it and problem fixed. If the fan is working then look at the design of the plastic leavers etc inside the unit that control baffles between the freezer and food compartments. It may be a simple matter of sliding one of these controls to make it colder where the food is stored. some of them also have an electronic control for this so look for that knob and turn it to colder...not the actual refrigerator thermostat but one that controls what they call "balance" between the freezer and food areas.
Aug 21, 2009 | GE Refrigerators
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
Gladiator 19 cu. ft. Chillerator Garage Refrigerator Logo
43 people viewed this question
Top Gladiator Refrigerators Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
