Question about Prestige Portable 320gb Usb 20 IOMEGA 34342 320 GB Hard Drive
Portable hard drive won't save info. Message says drive is read only
    Novelist:
  • 112 Answers
While the drive is attached to your system and you can access it, open "Computer" or "My Computer" (depending on your operating system), then Right-Click on the drive and a menu will appear. At the bottom of that menu click on "Properties" and then make sure the drive is not marked as "Read Only". Also, go to the security tab in the "Properties" window and make sure your Administrator account and User account have Write Access to the drive.
If the above does not resolve your issue, make sure there's no write protection switch of some sort on the drive. I've never seen one like that, but it's worth checking.
Also, you could try unplugging the drive, reboot the computer, then plug the drive back into the computer once it boots back into Windows.
I hope this helps!
Best Regards,
James
Posted on Jun 03, 2010
Testimonial: "Thanks for the tips. Didn't think to check properties. Really helpful. Best Regards. Gary"
Samsung M3 Portable Drive Diagnostic Fail Message
I would try creating a new folder (maybe TEST) on your portable drive, and saving 3-4 files (as copies) from your hard drive, say, a MS Word file, an Excel file and a .jpg picture. Close down your computer, remove the portable drive. Then start up computer again, when ready insert portable drive.
See if your computer recognises it, and then try to open the files you saved onto it. If that is OK it sounds like you do not have a problem. But treat it with caution for a week or two.
Jan 11, 2014 | Computers & Internet
Seagate expansion portable drive won't post makes clicking noise
Very likely the head is no longer aligned, and can no read the disc correctly. This is physical damage that can not be repaired. There are specialist, but at premium prices.
Oct 20, 2012 | Seagate Expansion 500GB External USB 2.0...
Sylvania SDVD6660 usb won't read portable hard drive
your hard drive must be formatted for FAT32 and NOT NTFS.
May 08, 2012 | Televison & Video
Cannot safely remove
Hi there
I have not come across that problem with my portable hard drive. But I always look at "bottom line" where the icon for the hard drive comes up, click on it then look for the sentence "it is save to remove the device now" .
Hope that you will get a good help with that.
Kolbrun
Feb 29, 2012 | Western Digital WD My Passport Essential...
My cpu won't recognize my LACIE Minimus Drive. I have no Setup Assistant and I need the info locked on the drive. What do I do?
Go download EASEUS Partition Master 5.8.1 Home Edition (free). I've found it very useful to check and often repair drives that won't mount.
Feb 26, 2012 | LaCie 1TB Minimus USB 3.0 Desktop - 301961...
I was told by your company to right click on the Iomega EGO and run the chk disc, went I do that there is nothing that comes up to let me do that. I also downloaded the HDtune.com and that shows there...
From your description the drive is clearly damaged and you will need data recovery help to save your data.
I recommend you try this guy first he operates remotely: http://FreeDataRecovery.us
If your data can not be saved remotely you will need to send it out to a recovery lab:
http://www.300dollardatarecovery.com/
Jul 19, 2011 | Iomega 500GB eGo Helium Portable 500 GB...
Error number = 6019 Get this message which
Its hard drive fail. on a wright error cannot read the file. hard drive will need replacing or re formatting can happen with power cuts so would check the cpu aswell.
Jun 20, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Hard drive fell can't read info
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 13, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
Can't figure out how to copy info from Passport to my hard drive
the question here is how did you manage to get the info saved into your passport portable hd in the first place? I don't mean to sound like a smartass but if you did save the files onto your portable hard drive before you wiped your pc's hard drive it should work the same way backwards if you want to access and restore the files back on to your pc from your portable hard drive.
now to answer your question you should simply...
1. plug your portable hard drive (I mean power and usb cable both).
2. turn on your passpost portable hard drive (if needed).
3. your computer should see your portable hard drive now being connected to the usb ports, wait a few seconds for the computer to recognize it and give you access to it.
4. if you don't a pop up asking you what to do with the new device you just connected (passport port. hd) simply go to start>my computer and under removable devices category you should see your portable hard.
5. double click your portable hard drive and you should be staring at the contents of your passport hd.
6. you can copy some or all the folders you find in your portable hd on to a folder that resides in "my documents" folder which is a folder that resides in your pc's hard drive. (if you are not accoustumed to move folder around from one device to another, please ask the help of someone that is familiar with this task or simply select a folder, right click on it, select "copy", then go to the target location, right click on an empty space and select "paste")
if you are not able to do this 1-6, you may have not completed setting your system, and it's possible that you may still need to install drivers for you usb hub (for instance) to have your system being able to work with usb devices.
post back with your findings and any details of any problems encountered along the way.
hope this helps!
Apr 22, 2010 | Western Digital Passport 320GB External...
Hard Drive failure
If you cant read the drive your info is probably gone but you could try a recovery program of some sort.if you can read from it save what you can.
Jun 20, 2008 | Maxtor Hard Drive
Prestige Portable 320gb Usb 20  IOMEGA  34342 320 GB Hard Drive Logo
250 people viewed this question
Top Prestige Computers & Internet Experts
David Payne
David Payne
richie46
ray gallant
Are you a Prestige Computer and Internet Expert? Answer questions, earn points and help others
