Question about Avaya Eurostyle 18D Corded Phone
Reprogramming the date for daylights savings time.
This year, the US Gov't changed the date that daylight savings time goes into effect, and my phone didn't switch on the new date. Thankfully, I was able to go into this website to learn how to set the time, so I set the new time on our phones manually. But now I would like to learn how to reprogram the phone so that it will change on the correct date itself.
From extension 10 or 11
feature 00
left intercom
left intercom
#126
press the 2 button
feature 00
That will disable it.
Posted on Jun 03, 2008
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do I change time and date on LG440G Tracfone?
On my model, I go to menu, then calendar, then calendar will show up & you can use arrows at the top to pick month & year, then once you got the right month, tap on correct day. that is for the date.
The time should come up automatically when you turn on your phone. Mine even changes to correct daylight saving time automatically.
Mar 09, 2015 | LG Cell Phones
The clock changes for daylight savings time on the wrong day. it did this the past few times the time had changed. the date on the back of the unit is 2004. didn't they move the weekend of daylight savings...
Daylight Savings Time was extended in 2007.. (the Act was in 2004)..
So your clock worked fine for three years.. now.. if you can turn this automatic feature off I suggest you do and just set it manually... otherwise you will make the change.. and it will make it again for you!
Best of luck
Mar 12, 2011 | Vacuums
Can not open programs since daylight saving tme has change. All programs were converted to something else. I cant get into to change daylight saving help!
Time change has no effect on programs working.
Try changing time in control panel Time&Date link?
Manually run the internet time updater?
What do programs look like they were converted into?
Different language? Check Language settings?
Hard Drive got corrupted? just a coincedence?
Apr 04, 2010 | ZT Group CISNET A7022 PC Desktop
4420 set to Central Time with Automatic Daylight applied reverts to Standard Time at power on ... has Daylight Savings not been applied ?
From the Start menu, select Settings >
Control Panel > Date/Time
to open the
Date/Time Properties control panel.
Use the arrows in the application to
navigate, increase or decrease the
time or date.
2. Select the year to open a field where
you can change the year by backspacing,
or entering a new year.
3. Select the month to open a pulldown
list of months.
4. Tap the checkbox to enable the Automatically
adjust clock for daylight savings
time
, if desired
Mar 17, 2010 | Datalogic Falcon 4420 Handheld Barcode...
Need to update daylight savings time date
This is from the Timex FAQs site:
Q: My clock did not update for DST.
A: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
Oct 26, 2009 | Timex T311T Clock Radio
Daylight saving time feature
Press
Function
71
set
key in date and time
set
stop
Mar 09, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Avaya Eurostyle 18D Corded Phone Logo
197 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
