Question about Jandy TELEDYNE LAARS GAS VALVE, PROPANE W/STREET ELL
Unit cycles in and out before reaching set temp
  • 33 Answers
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
We just had a dometic rooftop ac b59516.711co installed 2 weeks ago and today, when the desired temp is reached the unit will cut off but not come back on when temp goes above desired temp.
That is normal. Typically a unit doesn't maintain the exact Set point temp. If set for 75 it cools to 74 and doesn't restart until 76. Obviously if getting too much higher than that there is a problem. Units also are programmed with maximum and minimum run times as well as how many times it can cycle per hour. Hope this helps!
Jun 09, 2017 | Dometic Heating & Cooling
My ac randomly turns off and when I restart it it does the same again
HOME A/C units are designed to shut off when the desired room temp is reached.it is called Cycling. when the temp control unit senses that the temprature is too high then it will turn the unit back on till it again reaches the temp it is set oto
Oct 01, 2015 | AC Cars & Trucks
Outside unit runs for about 5 seconds then shuts off for a few seconds. It repeats this cycle.
Put in a 5 minute time delay. It is a two wire device in line with the contactor. Sounds like it is set to 75 turns of at 74 and repeats. The tstat should have a differential of 2 degrees as well.
Dec 22, 2013 | Heating & Cooling
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
UNIT KEEPS FREEZING UP. WE HAVE THAWED IT OUT MANY TIMES AND SAME THING HAPPENS. IS THERE A RESET BUTTON?
have you checked the filter ? do you have the temp set to low? are you trying to cool to big an area? shut it down again and let it thaw out. set the stat to mid range and trun it back on. close all unused rooms. when the unit cycles of and its still not cool enough turn the tstat down unilt it comes back on and leave it there.. unil the rom temp reaches 72-74 degree. thats the best set point .. you might be about to get it down to 70. but my bet is 1 dirty filter. and set temp to low.
Jul 16, 2011 | Heating & Cooling
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
Beverage air cycling off/on
These units are not designed to run in temps much lower than 50 degrees. They have no winter controls and the freon pressures will take a nose dive when running in a cold ambient condition. The unit will not run well in a cold environment, compressor damage may result. :(
Dec 16, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Tank temp
check to see if your element is scaled up or your element may be damaged
Nov 21, 2008 | Hobart AM15T Dishwasher
Thermostat ct87b
Your thermostat could be shutting off too soon. What you have to do is take the cover off of the thermostat and look at the bottom right side of the unit. There will be a Zinc plate with little dashs and numbers on it. on top of the plate is a copper triangle, that is what turns the heat off at a certain temp. The triangle is probably out of place and is cycling the heat off before it reaches your set temp. Just carefully adjust the triangle tward the lower left side of the triangle (alittle but at a time) and hopefully that will fix your problem.
Jan 21, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Motor never turns itself off
If by motor you mean the compressor itself then no, it should not run all the time. The compressor should run until the thermostat senses the temp. is at where you set it then turns off the compressor. A couple of possible things... if the unit has a leak in the refrigerant then it may run almost continuously since it can barely reach the cold setting you have selected. Or the temp. sensor thermostat may be bad and the unit doesn't know to turn off. There is also a defrost cycle that happens about every 12 hours for a few minutes (depending on make/model on how it works) but that should also turn off the compressor and fans until the defrost cycle is completed. Basically it should turn off when the temp. setpoint is reached or when it's in the defrost cycle.
Jan 14, 2007 | Admiral 26 cu. ft. Side-By-Side...
Jandy TELEDYNE LAARS GAS VALVE, PROPANE W/STREET ELL Logo
63 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
