Question about Jet 7 Portable Power Chair
I need manual for my Jet 7 Can you help me? - Jet 7 Portable Power Chair
  • 177 Answers
Hi. The easiest way might be to google "Pride Jet 7 manual", and see if you can down load one on the net. Otherwise contact your nearest pride dealer and see if they can get one for you. Good luck. Neil.
Posted on Jun 05, 2010
Hi got a sym jet 4 rode it parked it up and now no spark at all help please is this a comon thing 2014 plate to
Hi, Ben and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
no spark at all on 50cc sym jet euro sport Scooter Doc Forum
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
Sym Jet 50 Service Manual
SYM JET 50 Spares Parts Accessories
SYM Fiddle II 125 AW12W Service Manual
SYM JOYRIDE 125 User Manual
Jan 16, 2017 | Sym Motorcycles
2005 Yamaha R1 rough idle
Hi, Charles and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
http://www.r1-forum.com/forums/4-mechanical-help/179358-04-r1-rough-idle.html
05 R1 Very rough idle
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jul 10, 2012 | 2005 Yamaha YZF-R1
1995 Yamaha XJR 1200 cold start problems
Hi, Iain and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Starting Problem Workshop Help
legend cold start problems
YAMAHA XJR1200 FACTORY OWNERS REPAIR MANUAL 1995 2006 Download Manuals... $24
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jun 15, 2012 | 1995 Yamaha XJR 1200
97 yamaha 600r at idle the rpms slowly drop insted of a sharp drop when throttle is let off thinking the jets maybe stopped up or has a fuel return issue, or the carbs are not in sync. thanks
Hi, Etka2800 and the usual suspects are:
YZF600R Forums View topic Idle Speed
Need Serious Help High Idle
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Dec 13, 2010 | 1997 Yamaha YZF 600 R thunder cat
Jet 7 will go backwards, but cuts out and powerlight indicator flashes, when trying to go forward Bunnyxjs@Yahoo.com
bunny You will need to count the number of flashes 5 flashes pause 5 flashies etc This is a flash code and you can tell by that what the problem is. If you have your users manual it should have a section on flash codes. Hope this helps you
Sep 24, 2010 | Pride Mobility Products Pride Jet 7 Power...
Replacement batterys for jet 7 wheel chair?
Yep u need 2 U1 batteries. Check in your area for a battery warehouse type store or an Interstate battery store they can get the U1 s you need and might have them in stock. Try to avoid going to a provider as they will charge you alot more than the battery stores Hope this helps you
Sep 10, 2010 | Jet 7 Portable Power Chair
Jet 7 Portable Power Chair  Logo
71 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
