Question about Dynex 4-Port Ethernet Broadband Router (DX-E402)
I can only use my lab top in only one room wtih the router i want to be able to get a signal any where in the house
  • 11,896 Answers
You may have a small or weak router. Do make sure you are using an N or G series router for a good range.
Posted on Jun 03, 2010
Is it possible to Wirelessly connect Router to a Router? We have a Router (outside the house) by which we connect to the internet inside the house. The problem is is that the internet connection is not...
1.Yes you can connect router to router.
2.Buy ruckus 802.11n.It got MIMO antenna.I hope it will work for u.You can use single router to access internet from all room
Feb 04, 2011 | Computers & Internet
Tip
Using a network extender at home
Network extenders and repeaters work to extended the range of your wireless network. You don't have to live in a big house to need an extender, where I live houses are made of concrete which makes the wireless signals a little weak when you're not in the same room as the router. I had played with the idea of getting another router to put upstairs since the signal wasn't reaching from the office on the first floor to the bedrooms on the second floor. But setting up the router and the network was going to be time consuming and I was just trying to make the signal reach a little farther. That's when I discovered repeaters, I set up one repeater at the top of the stairs in my house where the signal began to weaken and ta da! The network now reaches the whole house at full strength and I didn't have to set up a new network.
on Sep 17, 2013 | Computers & Internet
THIS ROUTER WORKS FINE IF I AM IN THE SAME ROOM BUT IF I GO TO ANOTHER IT DISCONNECT. DO YOU THINK IT IS MY LAPTOP OR ROUTER?
Most likely it is a problem with the router. Is your house an older house? some of the older houses have so much wiring in them than it screws with the signal the router is putting out, or the walls are so dense that it screws up the signal. Take the laptop to someone else's house and try it out there. If you don't lose signal so easily somewhere else, then it's your router or the area of the house that your router is in.
May 23, 2010 | Belkin (F5D7230-4) Router (587009)
No signal with desk top but yes with notebook
make sure that wireless card is turned on. reinstall your wireless adapter driver. if nothing happened, consult to your manufacturer possible defective wireless adapter.
Apr 01, 2010 | Computers & Internet
Have a 2Wire Router from SBC that has recently been causing connection problems with my sons XBox. Low signal roughly 2 bars. Nothin has changed in the house. Have router in main bedroom, Xbox is in son's...
if signal is fading in and out there are a lot of factors. 1 have you installed an other electrical epuiment in the house? emf cause interference. 2 if you move the xbox to the same room as the router how is the signal? d3 do you have a laptop to try next to the xbox where it is at now and see the signal? if it is weak on ther laptop also get a new router.4 if the signal is good on the laptop your xbox is the problem.
Dec 30, 2009 | 2wire HomePortal 100W Router...
The ploblem is In need the solution of wire less network to build in the big house.
I presume you need Internet access in this house using a wireless network.
The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
Nov 04, 2009 | Adapters.com Computers & Internet
Problem with signal reaching PC when away from the router
On the wireless card there is two wires connected to it, a black wire and a white wire. Try reseating both of those wires back onto the wireless card.
If that doesn't do it then go ahead and reseat the wireless card itself back into the slot and see if that does it.
On both of these steps be sure to turn the laptop off first before doing them. Then turn the laptop on in both steps.
If that doesn't do it then your wireless card is faulty and needs to be replaced.
Aug 15, 2009 | Computers & Internet
Need a stronger signal for the wireles in our house
Your better off getting a repeater for your wireless and strategically place it in a room where it can amplify to the next and so on. Concrete is virtually impossible to pass through with the signals wireless transmit so a repeater strategically placed is the best way in my opinion.
Jan 30, 2009 | 2wire (1000-100016-002) Wireless Adapter
Dynex 4-Port Ethernet Broadband Router (DX-E402) Logo
35 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
