Have a hitachi 57f59j went to bed at 2:30 am got up had no power. Changed 3 fuses still nothing what could it be
  • 597 Answers
Power board malfunctioning
Posted on Jun 03, 2010
My Kenmore 795.78304.802 model just stopped working
i recently experienced this and found one of my old glass fuses had went bed it must be a fuse issue to have lost everything all at once i would start there
May 29, 2014 | Refrigerators
No power light on, no power at all
test the power cord for open, loose wires, bad contacts. Power switch dirty clean it. Clean contacts fuse for corrosion, and replace the new fuse with the same capacity, Tight the wires from fuse. If the problem persist, you have problem with the power supply from LCD TV. Time to go to the repair shop.
God bless you
Jul 11, 2013 | Hitachi L26D103 LCD TV
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
We have a Hitachi 57F59J, it is making a loud popping sound and the screen flickers, we took the back off. Sparks are coming from the right side, on one of the three boards. Can you tell us what this is,...
Don't plug it in anymore,it will cause more damage.The DM power supply board is dying.It poping capacitors like popcorns.Hire a tv tech. for this job,must trouble and repair.To find out why it killing capacitors this qiuck.
Sep 04, 2010 | Hitachi 57F59 57" HDTV
Hello. i have a zx5 2003 ford focus. I changed
battery clamps or terminals loose or corroded, bad ground wire from battery to chassis thats where i would start. check connection to alternator as well
Feb 16, 2010 | Ford Focus Cars & Trucks
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 51F510 with NO POWER
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
