Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
The water wont drain but it does spin and everything else seems to work
  • Frigidaire Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinethe water wont drain but it does spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
  • 262 Answers
SOURCE: washer wont drain
check the pump for socks or anything that dont belong but put your hand on it while its in spin/drain and see if pump is even running
Posted on Dec 21, 2007
SOURCE: Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Posted on Dec 29, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Posted on Apr 17, 2009
jsrock516
  • 5911 Answers
SOURCE: washer fills with water but wont drain
Check your lid switch. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have any questions, please let me know. I hope this helps you.
PS You do not have to drain the washer to complete this repair. Once the switch is replaced the washer will drain on its own. This may save you the need to bail water again.
Posted on Jul 20, 2009
SOURCE: Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Posted on Aug 15, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Capri washer
Commonly the drain pump is run by a belt drive, which has possibly broken. You should be able to take the back panel off the washer by undoing several screws, and then look to see if anything is obviously broken.
Aug 24, 2013 | Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
Aug 14, 2009 | GE WSXH208A Front Load Washer
Wont spin does everything else but spin
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Model # mav7700 AW wont drain
Dear Customer
Please perform the following
Please rate this,Thank u
Dec 16, 2008 | Maytag Washing Machines
Dec 21, 2007 | Admiral AW22 Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
152 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
