Question about Dell Inspiron 6400 Notebook
Inverter are there any tricks to this repair i shuld watch out for
  • jtipler Apr 10, 2008
    I have a 6400 that I am fairly sure the inverter is out, I can see the startup screens faintly in the background. no Idea how to do it, any help would be nice
  • 46 Answers
Http://support.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270 shows you how to get to it. The part should be less than $40. Do a search on "Inspiron 6400 inverter board".
Posted on Apr 11, 2008
Backlight inverter board for LG TV What is correct part to restore illumination to TV
LED TV Repair Tutorial - Common Symptoms & Solutions ...
? 6:43
https://www.youtube.com/watch?v=8HG7efTMj78
Jan 3, 2014 - Uploaded by ShopJimmy.com
LED TV Repair Review & Overview-Common Problems - Symptoms, Solutions Click Here to BUY TV REPAIR PARTS: ...TVs inputs and outputs, this main board is connected to thebacklight inverter/LED driver via this ribbon cable. ... ofillumination for the screen and the board that drives thatillumination.
LCD TV Repair Tutorial - How to Replace the Backlight ...
? 2:30
https://www.youtube.com/watch?v=s3r1GZCA0K4
Dec 31, 2012 - Uploaded by ShopJimmy.com
Philips TV Repair Flickering Image On TV Screen Tutorial Guide How to ... Inverter on LCD TV Easy Fix Help Click Here to BUYTV REPAIR PARTS: h... ... How to Replace the Backlight Inverter Board in LG & Philips LCD TVs.Missing: restore ‎illumination
Sanyo 42 led lcd tv - Engine cork
Jan 27, 2016 | LG Televison & Video
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Brake judder
warped disks spin the disk with tyre off and watch it against brake pads does it stick when you try to hand turn it it shuld wobble when you turn the disk
Aug 24, 2012 | 2006 Peugeot 207 1.4
Picture keeps going out on Philips TV 47PFL3704D/F7, 2009 model. The sound stays on. It happens very randomly-may be fine for several hours, may happen every few minutes. Also happens when playing video...
I think that the connectors from the backlight inverter board that go to the LCD panel's backlight are a bit loose which explains why it comes back on when tapped. I am positive that unplugging and replugging the inverter cables should do the trick. WOuld like to do it yourself? It requires you to open up the tv ofcourse.
Jul 10, 2011 | Philips 47PFL3704D 47 in. LCD TV
Getting the back of an Armitron watch back on
You are going to need professional help for this one.
Recommendation:
Take your watch to your local watch repair shop they have a watch press that will press the back cover on.
Hope this tip helps.
R/
David
Feb 06, 2010 | Watches
I had a stem replaced in my Citizen ECO drive mens watch.
Nothing is right here. First of all you have to go back to that watch repair shop and ask for receipt for what was done. Stem itself cost about $3-$5 and the rest is charged for quality workmanship. Yoy must get full description of work done. Watchmaking trade rules are very strict and if there were any other faults than the faulty (broken) stem, they shuld inform you ASAP and explain all the job and extra money involved.
And the most important - no decent watchmaker can return watch to the customer without properly checking it's timekeeping, functions, e.t.c., so, the only one to blame is the company who did repairs.
Copy receipt, write an email and contact Citizen directly, explaining everything to the smallest detail. They shuld give you full support and even return the money if you are lucky enough.
You can find email and address here:
http://www.citizenwatch.com/COA/English/service.asp
Rate me, please.
Aug 04, 2009 | Kenneth Cole 1213 Wrist Watch
I cant see anything on the tv and i have 'the ring of fire' HELP!
your 360 is suffering from the "red Ring of Death", and will need to be sent away for repair or replaced outright.
Jun 12, 2009 | Microsoft Xbox 360 Console
Trouble codes f5-2 sharp al2030
Hello sir; I believe when you make copy shuld be all black, the F5-2 telling you the exposure lamp is bad or inverter board is bad, check the exposure lamp continuity first.
Jun 08, 2009 | Sharp AL 1631 Copier
Hi.i have sony ericson k790i mobile.
hey u go in settings n then in manage calls... then click in restrict calls.. n there will be an option deactivate...click tht it will deactivate all ur restricted options
Jan 17, 2009 | Sony Ericsson K790i Cellular Phone
Dell Inspiron 6400 Notebook Logo
143 people viewed this question
Alun Cox
