Question about Electrolux 504199 Dishwasher
Electrolux dishwasher buttons show lighted up but will not turn on I would like to know if the rinse is empty would it cause the dishwasher not to turn on? I cannot think of anything else that is wrong.
  • sathyin23 Jun 03, 2010
    1)whether machine running wash cycle completly?
    2)when the light getting on after the wash cycle cmplete(or)before?
  • 159 Answers
Hi there.Has child lock been activated preventing buttons from working.Either turn child lock off or try unplugging for 30secs.
Posted on Jun 04, 2010
C8 fault code
C8 = During rinse phase boiler doesn't empty
possible causes:-
Are the rinse arms clogged?
Does the rinse pump work correctly?
Is there water in the level sensor tube?
Is there scale in the boiler?
Does the boiler level sensor work properly?
CAUTION: RESETTING THIS ALARM WITHOUT FIRST ELIMINATING THE CAUSE IS DANGEROUS; THE BOILER HEATING ELEMENTS COULD WORK DRY, FURTHER DAMAGING
THE INTERNAL PARTS OF THE DISHWASHER.
CAUTION: C8 IT MUST BE MANUALLY RESET AFTER ELIMINATING THE CAUSE OF THE
MALFUNCTION
Jun 25, 2014 | Electrolux Dishwashers
I have an Electrolux Dishwasher that always starts on low rinse
Hello Friend, this is Z. Thank you for your post!
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Jun 04, 2014 | Electrolux Dishwashers
Electrolux Dishwasher model EIDW6105GS1A, heavy light on, won't start. Turned off circuit breaker for dichwasher and the light turned back on and it won't start still. No lights on behind kickboard to show...
Good Morning Kim,
I see that the heavy light is staying lit on your Electrolux dishwasher, model# EIDW6105GS1QA, even after resetting your appliance at the circuit breaker. I also see that there are no lights lit up behind the kickboard, indicating what might be failing. It could possibly be the control board underneath your dishwasher. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the heavy light to stay lit. I hope this is helpful.
-Best Regards-
WP
Apr 28, 2014 | Electrolux Dishwashers
C8 error on Electrolux commercial dishwasher
A C8 error means that the boiler isn't emptying correctly during the rinse phase. Check to make sure that the boiler and the spray arms are clear of scaly buildup or anything else that could plug them. You want to make sure that the rinse pump and the level sensor are in proper working condition too.
If you do find something that you think could be the cause of the emptying problem, check it out before you reset the code. This is one of those really important codes, because if you just reset it without fixing it, the boiler heating elements may end up working dry and that can seriously damage your equipment.
Hope that's helpful!
May 08, 2013 | Dishwashers
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 | Dishwashers
Water does not empty completetly after the cleaning and rinse cycle is completed
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 26, 2010 | Electrolux EIDW6105GB 24 in Builtin...
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Jun 25, 2010 | Dishwashers
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Electrolux 504199 Dishwasher Logo
366 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
