Was starting up my 60g ps3. I saw that the led lights went from green- yellow- red. I read that its overheating so i leave to cool down for the rest of the day. However, the nextt morning i see that nothing has changed. How can I fix this?
It can be overheating but it can also occur for no reason whatsoever. I did a little reasearch and found somone that had managed to get his ps3 working by pushing down on the metal shielding in between the power supply and wifi board, I know it sounds stupid but I tried it out on a coustomer's broken ps3 with the same problem and it worked. My guess is that the spot i pushed down on has a thermal resistor underneath with a bad solder connection or somthing. Tthe only problem is to do this you must take apart your ps3. Have either of you ever taken apart a ps3? If not, you either need to take it to a repair shop or call sony and have them fix it.
One of the YLOD threads (go search for it if you want to see the details) states that one of the eBay companies that repairs PS3s has determined that most of the YLOD errors are caused by solder failures due to repeated heating/cooling cycles. The solder cracks and the contact to the chip/component is lost, thus the system shuts down. The fix according to this thread is to re-flow the solder (essentially reconnecting the components). They stated that about 80% of the YLOD problems were resolved by this method. The problem apparently is either on the mobo or in the power supply. I'm not stating that this is gospel truth, but it's what I've read in other threads on this forum and it makes sense.
I've provided the dns numbers from my router setup to my ps3 and matched the ip address' but it...
(More)
I've provided the dns numbers from my router setup to my ps3 and matched the ip address' but it still won't connect.
I have that dns error with my ps3 I've entered all the dns numbers in and still no dice. I went into...
(More)
I have that dns error with my ps3 I've entered all the dns numbers in and still no dice. I went into the router and changed the ip address and I found the dns numberson the laptop. But it still displays the error.
not able to connect to the internet, no longer using belkin, using netgear.. asking for a wpa key?...
(More)
not able to connect to the internet, no longer using belkin, using netgear.. asking for a wpa key? where do i find this key/
I have been given what seems to be an older version of a ps3 (only 2 usb ports)The blue ray player...
(More)
I have been given what seems to be an older version of a ps3 (only 2 usb ports)The blue ray player is apparently broken but I've been told everything else works. I was not given a remote control and have tried to start it up using my own ps3 remote but it doesn't respond. tried using a controller with a direct cable and no luck? I just want to start it up to see what does work and doesn't. can you help please. Jollyboy
