Question about Microwave Ovens
I have a kenwood newyork smoothe machine,the problem is after puting choped apples in,the cutting blades will only pulverise some apples creating little apple pulp,how do you overcome this problem?
    Guru:
  • 302 Answers
Maybe the blades of your machine need Resharpening/Replacement. Also try using the supplied "Stick" to force the apples into the blades.
Posted on Jun 03, 2010
We have discoverd a air line crack in our granite bench top it starts from the out side edge and run along about 70m/m. how can i provent it getting any worse , regards ernest
The way to stop a crack is to drill a hole at the point where it peters out. Providing that the crack isn't actually in the stone beyond the hole and just under the surface, this will stip ot spreading.
Ideally, I would suggest a hole about the size of a cigarette, or a little larger.
KEEP the dust that you drill out from the hole!
To hide the hole that you have drilled:
  1. Get under the work surface and tape over the bottom of the hole.
  2. Now, fill three quarters of the way up the hole with epoxy resin (Araldite will do fine) and allow this to set
  3. Now take your drilling dust and mix it with a tiny amount of the resin (Just enough to make a paste that you can manage and that will still flow enough to slowly settle flat).
  4. If you can, save some dust in case you need to repeat the repair.
  5. Pour your granite repair mix into the hole and allow it to stand slightly proud of the surface
  6. Keep testing the leftover mix you have until it is card enough to press on with a finger, but soft enough to cut with a blade.
  7. Once the repair has reached this consistency, take a brand new sharp stanley blade and holding it at about 45 degrees to the surface, shave off the excess resin/granite mix
  8. Leave the repair to set hard (at least 24 hours)
  9. Once hard, use 1500 grit wet and dry paper and lots of water to smooth the repair surface
  10. This is the point you may find a small blemish and feel the need to use the saved powder to re-fill a small hole and repeat from step 5
  11. Now polish out with a cutting compound. You will find T-Cut or Brasso work well for this.
Hopefully, you have a fairly well hidden repair and your crack has sttopped
Aug 03, 2011 | Microwave Ovens
I have a Kenwood bread machine & for 3 1/2 weeks have been endeavouring to replace the"pan". We have called the firm you suggest but they cannot get an answer re stock from yourselves. We...
This service you are connecting to is not Kenwood, nor are we related to Kenwoo, but I will try to help you. Without knowing your model of breadmaker, I can only direct you to general site that lists all of Kenwoods models and you can choose your model and the part you need. I assume you are located in the UK,so go to the link below and you will see all of the models Kenwood sells. Select your model and your pan should be listed as a purchasable item:
http://www.torreelectrics.co.uk/acatalog/Kenwood_Bread_Maker_spares_and_spare_parts.html
Please let me know if you have more information for such as your location, the model number and I will tell you where you can find your part. I hope I was able to help you and look forward to hearing from you soon.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Kenwood Microwave Ovens
I need the manual fro Kenwood Tri Blade HB724
The model that you listed is the Kenwood TriBlade Mixer model HB724. The link below includes specs of the mixer and a instuction manual from kenwood.\
http://www.kenwoodworld.com/uk/Triblade-Global-Landing-Page/triblade-home/Range1/HB724/
Dec 22, 2010 | Microwave Ovens
I need a kneading blade for a model ABM6200 Welbilt bread Machine. Where can I purchase this item? I cannot even find any info on this model...? Any assistance would be appreciated! Thank you in...
I have a kneading blade for the ABM6200 welbilt bread machine. I sent it out to have it teflon coated and it is really great. Unfortunately my bread maker broke and I never installed the blade. I have the blade and the manual if you are still interested.
Oct 04, 2010 | Welbilt Microwave Ovens
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
Aug 25, 2010 | Microwave Ovens
Could you please explain how I can remove the motor from the casing of my Delonghi coffee grinder model DCG-2. As far as I can see I need to remove the s/s cutting blade....is this a press fit or...
Is your unit still under Warranty? If so, your warranty will be void if you do any kind of maintanence before contacting the Customer Service Department first. What area do you live in?
Jun 02, 2010 | Microwave Ovens
How to replace lightbulb
The screw(s) is/are usually a modified TORX T-20 or T-25 bit adapter. Sometimes you can very carefully use a standard T-20/25 bit adapter to get the screw loosened. Use a small flat blade screwdriver that has been modified with a slot cut into the center of the blade end to bypass the center pin. First find a narrow enough flat blade srewdriver that you don't care about and make sure it fits rather snugly inside the screw-head just for a loose fit. If the blade is a bit wider - no problem - it can be ground down to fit snugly. Next - using a dremel tool and diamond cutting wheel attachment (or similar) cut a slot into the end of the blade. Make sure that the screwdriver is going to bite the insides of that screw-head first though before wasting a perfectly good screwdriver. You will have to adjust by trial and error until you get the blade to fit perfectly the head of the safety screw. If the screws are really tight use a pair of vice grips to clamp the screwdriver blade for extra leverage.
Dec 25, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Jenn-Air JMV9169B top cabinet stencil
I would suggest contacting Jenn-Air / Maytag / Whirlpool customer service on this one.
Nov 01, 2008 | Jenn-Air JMV9169B Convection/Microwave...
My Hamilton Beach food processor cutting blade does not rotate. Power is getting to the blade because the light is on and the unit is humming.
Chances are you have a worn rubber or plastic clutch.
Most stores that sell these have replacement clutches.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Microwave Ovens
Lightbulb in Emerson microwave model MW8115 SS
You have 3 choices to use on removing the safety screw(s) on the MW (microwave or nuker as I call them) cover.
1 - The screw(s) is/are usually a modified TORX T-20 or T-25 bit adapter. Sometimes you can very carefully use a standard T-20/25 bit adapter to get the screw loosened. Sometimes! If that doesn't work then you have option #2.
2 - If #1 doesn't work you can use a small flat blade screwdriver that has been modified with a slot cut into the center of the blade end to bypass the center pin. First find a narrow enough flat blade srewdriver that you don't care about anymore, and make sure it fits rather snugly inside the screw-head just for a loose fit. If the blade is a bit wider - no problem - it can be ground down to fit snugly. Next - using a dremel tool and diamond cutting wheel attachment (or similar) cut a slot into the end of the blade. Make sure that the screwdriver is going to bite the insides of that screw-head first though before wasting a perfectly good screwdriver. You will have to adjust by trial and error until you get the blade to fit perfectly the head of the safety screw. If the screws are really tight use a pair of vice grips to clamp the screwdriver blade for extra leverage.
If neither of these methods work for you or you can't modify a special tool then you will have to do the last option.
3 - Using an easy out of proper size drill out the center pin and then use the proper "easy out" to back out the screw. Discard that/those screw(s) and replace with regular phillips head screws after replacing the light bulb.
Hopefully you will be able to do this repair yourself? Otherwise if your neighbor is Tim the Toolman Taylor I'm sure he'll be able to give you the necessary hand to do it for you.
Hope this helps fix your dilema you are in.
One note here -
Make sure you unplug the nuker first and be VERY CAREFUL as to NOT TOUCH the HIGH VOLTAGE CAPACITOR inside. Otherwise you risk a chance of SEVERE HIGH VOLTAGE SHOCK!!!!!!!!!
BE VERY CAREFUL....
Best regards,
Frank
Feb 27, 2008 | Emerson Black Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
