Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction hose not picking up
The hose usually picks up very well and now it is making a strange noise and not sucking up through the hose. the other upright vacuum is working well and sounds like it usually does but, when it switches to the hose it doesn't ****.
  • chrissy88 Apr 19, 2008
    I am having the same problem. I can use the "floor" part of the vacuum. Pushing it across the floor, but when unhook the hose to use it - the "noise" the maching normally makes stops as if something is blocking it....and won't **** up anything!
  • 372 Answers
Hi.
You have blockages in the hose & wand remove these from machine & clean them out.
Check (U) shaped inspection port bottom back of machine usually has A pen wedged in there,
http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
Suction: I took the beater head off to get debris out from under it. when I put it back on I didn't have suction on the beater part. I have suction to there but none under neath
Hello, this is Ava with Think Crucial.
Most of the time the reason why vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. Please refer to this troubleshooting guide for more information on how you can remove blockages:
https://www.dyson.com/support/dc65/dc65-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc65
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 15, 2016 | Dyson DC65 Animal Upright Vacuum Cleaner
Hose doesn't have suction
Hi Danny,
I am sorry to hear you are having difficulty with your DC18. I understand you have checked for obstructions, however, the problem you are describing sounds like a blockage. Please click on the appropriate link below to view step by step instructions on how to locate and remove a blockage in the wand, hose and the hose inlet. If you prefer we would also be happy to walk you through these checks over the phone. If the problem persists after the recommended trouble shooting steps have been carried out, please call us directly as your machine may need to be serviced by an authorized Dyson technician.
Link to Dyson support page US:
http://content.dyson.com/support/help.asp?article=1049&product=DC18-ALLFLOORS
Link to Dyson support page UK:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If you determine you need further assistance, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jessica
Dec 11, 2012 | Dyson DC18 all floors Bagless Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My hose tools wont pick up. when hose tools unattached suction is fine and will **** my hand fiercely, but once tool attached no suction..... how am i gonna pick up cat hair from seats now?! its a dyson...
I have a DC04 and the hose tools are a open hole.The only reason they want pick up is they are blocked.If you say they are sucking your hand when not attached.Make sure the hose is not blocked by taking off the cover at the front.Allso check the cylinder rubber seal is sealing the dust container.Thats the only problem i had with mine.Good luck.
Jul 31, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Kirby g5 suction problem
If its not picking up as an upright but does with the hose, youve either not connected the belt or the belt is broken
Feb 17, 2009 | Kirby G5 Bagged Upright Vacuum
I have a Kenmore Grab n Go Bagless and it won't pick anything up. I've cleaned the filter and the hose and the roller.
I assume you have no suction?
Could be either a seal is missing or there is either broken impellers on moter or debris caught in impellers or screen protecting impellers. Check to see if you feel air bblowing out or strange noises.
Jan 23, 2009 | Vacuums
Looud noise and no suction
the motor impella is blocked. you have to access this from the bottom
Jan 23, 2009 | Kenmore 34720 Upright Vacuum
No suction.
Mine is doing the same thing, the hose picks up things fine but the rollers turn and instead of picking up it is blowing air out????
Nov 29, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Dyson dc05
your vacuum is not picking up because the infamous dyson has lost suction "which they claim to not do" first you have to make sure the filters are taken out and cleaned, then check the hose and make ure there are no clogs in there. usually they are see through so they will be visable. also make sure there is no debre blocking the cones on the machine
Sep 12, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
181 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
