Question about HP Business InkJet 2300 Printer
Error message 0096-e8bb slavecleaver.cp: 150 - HP Business InkJet 2300 Printer
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Printer Brother DCP-150 cp Unable to print
Remove foreign material in ptinter or change maintenance unit
Dec 22, 2013 | Computers & Internet
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Since last night i have not been able to recieve text messages , i can send them but not recieve them.
Please check the capacity of your cp, or up to how many messages can be stored in your cp.Usually, it'll prompt you if your cp has FULL MESSAGES; but if there's none, try deleting some of your un-important messages both in your INBOX & SENT messages.
May 11, 2011 | Cell Phones
The tv will not power up. Blinks three times and shuts down. TL010 shorted ,replaced but still has problem.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented)
Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Where to oil the compressor
I have a Powermate cp-150 pancake style compressor that has teflon style piston ring that requires no oil. The bearing on the crank/rod is sealed and replaceable with generic (look for bearing number on dust shield of bearing). Just use it untill it gives up. First signs of problems is that it will take a long time to fill or never reaches cut out pressure. Good Luck and save your oil!
Oct 05, 2009 | Air Tools & Compressors
Rca tv
ck cp 150 2200uf 16v cp 111 220uf 35v and cp 114 220 or 330uf 35v replace all 3 capacitors
Nov 26, 2008 | RCA D52W19 52" Rear Projection Television
Capacitors
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
138 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
