Question about RCA RS2664 Shelf System
RCA RS2664 Stereo
I can't get my CD changer to open, play, or eject.
  • 3 more comments
  • Pamelijo Apr 09, 2008
    The device powers up. I moved it from one shelf to another and it had CD's loaded. I read in the manual (leter) that you shouldn't move it with CD's loaded in it.
    I can open the door manually and believe I removed all the CD's from the tray. I'll check again this evening when I return home. I'll let you know something in the morning... Thank You
    By the way... I can select the CD buttons 1-5 and the display indicates that CD 1, 2, 3, 4 or 5 is playing... but alas it is NOT
    I opened it manually after trying to use the eject button without luck. I don't think there is a CD stuck inside, but will look when I get home. All I did was move the dang thing with CD's in it and now it won't eject, open, or play.
  • Pamelijo Apr 10, 2008
    Okay... I unplugged the speakers and the power to the unit, turned it to the left and shook it, turned it to the right and shook it, turned it upside down and shook it. After plugging the power back in the CD changer came alive and ejected the CD that was loaded in it. The unit now plays, ejects, and opens as it should.
    Pam
  • 813 Answers
Hi friend
u have your problem in a your cd tay belt so u have to change it & ur cd open & close problem will slove this problem come due to belt is lose so go with a good cd reparir & change the belt of ur cd try its take 5$ to 10$ to change it
thnx using fixya
Posted on Apr 09, 2008
  • 2,323 Answers
Do you know by any chance if a CD might be stuck inside?
Does the device power up?
  • Jaime Hernandez Apr 09, 2008
    Try to open the cover and remove the CDs manually. I'm sure that one of those CDs is not letting you open it.
    Let me know if you need further assistance.
    If the CD tray was opened manually, there might be a possibility that the loading mechanism is out of alignment and is not activating a switch that tells the microprocessor that the tray is open or close.
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Feb 15, 2012 | Alpine CHM-S630 6-Disc CD Changer
The magazine for my CD 12 disc changer will not eject nor will it play ant CDs. It seems to be getting power as the light inside the slide door lights up as open to eject the magazine any suggestions? It...
theres usually a reset button hidden inside the door on the cd changer. use a paperclip to reset the device. sometimes theres a reset on the controller part of the cd changer Up by the radio ( if you have tha type )
Jul 31, 2010 | Pioneer Car Audio & Video
6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Sep 29, 2009 | Car Audio & Video
My Pioneer DEH-P835R Cd Player will play my cd but wont eject
Check in the front and you should see a small hole thats about the same diameter as a paper clip. Open up a paperclip to a straight 2 inches and poke it through the hole. It should release the door so you can get it open or at least seat the cd if thats whats making it not open.
Apr 26, 2009 | Pioneer DEH-P835R CD Changer
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
No Play No Eject
COMMON PROBLEM
OPEN IT UP AND REMOVE YOUR DISC AND THEN THROW THE PLAYER AS FAR AS YOU CAN.
Jan 26, 2008 | Nakamichi MB-70 6-Disc CD Changer
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
RCA RS2664 Shelf System Logo
283 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
