Question about Sanyo DP32746 32 in. LCD Television
When i hit the power button it clicks like it wants to turn on but the screen does not come on, and no sound. it does not get hot or produce any heat.
  • bubb68 Jun 03, 2010
    Kidsasuke,
    it is an LCD, it clicks, but the sound doesnt work either. if it is a bad backlight circuit, how will this explain the sound not working? it worked fine for several months, then nothing, it was always connected to the satelite box the same way. but now no picture or no sound
    Scholar:
  • 121 Answers
Your backlight circuit might be fried if it's not a CRT (big clunky picture tube). The backlight circuit generates the most heat in an LCD or plasma TV and allows you to see the pixels being generated on top of it. Sometimes these problems can be fixed, but about 75% of them are just biffed into the garbage and are replaced.
Posted on Jun 03, 2010
  • Doug
    Doug Jun 03, 2010
    If there's also no sound with the no picture, then perhaps the power supply is screwed. I can only assume it'd be either that or the digital switches that are used to turn it on might be fried. Without being able to actually work on it and perform full diagnostics, there's not really any way to properly determine the issue.
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Motorcycles Not getting spark from back 2 plugs
Sounds like you have power to the coil, but the coil is faulty and not producing a spark.
Remove the coils. Put power to it, you should get a spark when you remove the negative lead.
Oct 05, 2017 | Honda Shadow Spirit 750 Motorcycles
I was riding the tractor mowing shut it off to get lunch returned 1 hr later would not start. I bought a new battery and had the starter checked all good still wont start. I get a click when i turn the key...
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
May 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
Sound is off. kids playing on it. have hit every sound button on keyboard. is there a mute button? Thanks
Go to: Control Panel > Sound and then a box will pop up. Click on Playback tab and make sure your correct speaker output is selected as the default. Then click Apply button. Then OK. Also, to check your mute/volume button click the speaker icon on your task bar (its next to the little clock in the bottom right of your screen. You might have to click a little arrow that looks like this < to see it. Then just turn up the volme. Also, make sure the speaker cables are plugged in and the power cord as well if they are external speakers.
Dec 07, 2009 | Microsoft Wireless Laser Desktop 4000...
Sings when producing hot water
it is a loose washer in a valve,,, when the water hits it just right it makes the sound,, either check the valve by turning it on and off while water is running that will let you know wich one it is
Apr 19, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Dec 13, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sanyo DP32746 32 in. LCD Television Logo
105 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
