Question about Radio Communications
I have a motorola AAM25KKD9AA2AN radio. When I key the microphone the radio powers off and when I release the microophone it powers back on. If I remove the antenna, it does not do this.
  • Radio Commun... Master
  • 1,654 Answers
Sounds like a power problem. Check your wiring and battery connections. Or if using this radio as a base station with a power supply, check your wiring and the power supply. You are likely not getting enough power to operate the radio.
By keying the mic without an antenna connected you are creating high VSWR which is hard on the radio. It reflects power back into the radio and pounds the power amplifier. The reason the radio is staying on is likely it takes less power without the antenna connected. While examining the radio, double check your antenna connections and coax.
Best regards.
Posted on Jun 03, 2010
Make sure your antenna is matched. The radio may be shutting down do to a shorted coax or high SWR.
Posted on Feb 28, 2013
Why does mic key up and shows dead key but will not transmit,just stays on dead key until you release button
What type of radio do you have? Does the radio transmit but no audio is transmitted? It may be as simple as a broken microphone wire. Please give us more information.
May 24, 2016 | Radio Communications
Microphone recommendation for KLM-2700
Just about any mic will do. I have used a Midland, Motorola, GE, Radio Shack and other microphones on these radio's. The mic element must be dynamic. Condenser microphones would require you to slightly modify the mic input circuit of the KLM to provide 5 to 10VDC through a 4K7 resistor to provide bias for the condenser element. It's easy to do if you have the skills to do it.
Jan 30, 2014 | Cobra Hand Microphone Wired For Klm Multi...
Need a wiring diagram for a motorola aam25kkd9aa2an radio
Hi Judy,
Motorola yes, model=aam25kd9aa2an No.
The model number is somewhere on the front of your radio in line with Motorola brand.
The number you've given makes no sense at all.
Please reply with the correct details, and the more details about the fault the better we understand the problem, this way we can find a solution for you.
Cheers,
Peter
Feb 26, 2013 | Radio Communications
Motorola two way radio rdu4100 which remote speaker microphone fits this radio?
PMMN4013 Construction Grade Remote Speaker Mic OR
PMMN4029 IP57 Rated Construction Grade Remote Speaker Mic.
Best regards.
Sep 27, 2012 | Motorola RDU4100 Two Way Radio
Motorola CLS 1450c radios microphone problem.
The problem you are experiencing is not a mic problem, or the problem would also be associated with the two-way radio portion of the radio. Your radio is either in need of repair or you have a bad, low or defective battery. It takes more energy to transmit or use the unit as a phone than to simply receive.
If your radio is under warranty (less than 1 yr old) you can return it to the place of purchase for warranty replacement or service. After warranty repair is also available through Motorola's factory depot. Ask your local dealer.
Feb 16, 2010 | Motorola CLS 1450CH (4 Channels) 2-Way...
Motorola SX700 battery drainage w/tactical mike
It is likely the mic set you are using is not made for the SX700 radio, and is drawing too much power from the radio. Some audio accessories draw more power than others. It is possible your mic set is intended for a professional model radio which would supply more power to the device. You should check with Motorola to see if they have a mic set similar to go with your SX700 radio. Here is a link to their online store: http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=130652F39955D9E9CA94908C45C73822.mot3?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle
Oct 18, 2009 | Motorola SX700R 12-Mile FRS/GMRS Radio...
The mic doesnt work ...it use to but all the sudden it quit doesnt even key up so i can hear it my talk back
First, try another mic on the radio to be sure it's the mic and not the radio causing the problem. If it's the mic, check the wiring circuits for a bad switch or broken wire. Simply...the TX circuit is closed and the RX is open when the key is squeezed. The RX circuit is closed and the TX circuit is open when the key is released. Use a simple ohm meter to check for resistance between the pins on the mic (after removal from the radio of course). Open circuit will read 1, closed circuit should be very close to zero. You'll probably find the TX circuit never closes when the key is squeezed. Could be a broken wire or faulty switch in the handset.
Also check...If the mic "keys up"...you see the meter move normally, but no voice...it's either a faulty mic element (the little round thing you talk into) or the audio circuit of the radio has a defective component which a good CB shop can replace.
Jun 14, 2009 | Astatic 636L Noise Canceling Microphone...
Repeated clicking(transmitting) noise from Motorola Talkabout
Moisture and oxidation on the circuit board will create noise during transmission. You may remove the cover and wipe around microphone and the circuit.Ensure its dry. Cover it back and test.
Mar 01, 2009 | Motorola Talkabout T4500 (7 Channels)...
One of my Motorola T4500 walkie talkies has a ghost inside it....
Feb 25, 2009 | Motorola Talkabout T4500 (7 Channels)...
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
362 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
