Question about Compaq Presario CQ50-215NR Notebook
I press the power button and it turns on. I can hear the fan running. Nothing ever comes up on the screen, the screen doesn't even flicker.
    Guru:
  • 592 Answers
When this happens, there are a few things that may cause it. First thing is if you get any beeps that are not normal for the system when it turns on.
Beeps other than a quick beep beep, are the result of the computer not passing POST (power on self test). The beeps will let you know the error detected.
If there are no beeps that are not normal for this unit, then i would look next to the screen to see if the inverter or lamp is blown. Look closely at the screen and see if there is a picture but it is really faint. If there is a picture then it is the LCD lamp or inverter, it will need to be serviced to determine which and replace them.
If there is no picture at all, even a faint one then you have a hardware or power management problem.
To clear the power management, remove the AC plug and battery from the system. Hold the power button in for atleast 15 seconds then release. Plug the AC jack in and attempt to boot. If it does not work then move on to hardware.
First thing in hardware to look at is the memory. Remove the memory from the system and try to boot. With no memory you should be a post beep error. If you do then put 1 stick of memory in the system and try it. If it boots, shut it down and remove that stick. Place the other stick in the same slot you just removed the first one from and try to boot. If you don't boot then it is that 2nd stick if you do boot, Repeat these steps but with the 2nd slot. If the system does not boot at all with the 2nd slot that slot or controller is damaged. Take it to a service center.
Another thing you can look at is connecting the unit to an external display or lookign on the keyboard for a lcd button on one of the F keys. hold down Fn on the keyboard then press that, it coudl be that the display is showing to external and not internal LCD.
If none of these work, it is best to have the unit serviced
good luck.
Posted on Jun 03, 2010
  • 2,404 Answers
Unplug the battery and only hook up the ac adapter. See if you can get it to turn on.
If not then take out the memory and then reseat it one memory stick at a time in each slot one at a time. Try turning the laptop on after each reseat, this will check each memory stick and each memory slot.
If you still can't get video then go ahead and take out the hard drive and dvd drive. Now try turning on the laptop again. If you get no video this time then that means the motherboard is bad and would need to be replaced.
My hp touchsmart310 PC will switch on but there is nothing on the screen ?
You can perform these steps even though the screen is blank.
  1. Turn off the computer, and then remove the power cord.
  2. With the power cord disconnected, press and hold the power button for five seconds.
  3. Reconnect the power cord, and then turn on the computer.
  4. Repeatedly press the F10 key about once every second for five seconds after turning the computer on.
  5. Wait five seconds.
  6. Press the F5 key. This restores the default settings of the BIOS.
  7. Press the Enter key. This accepts the changes.
  8. Press the F10 key. This opens the Save and Exit window.
  9. Press the Enter key. This saves the changes, exits the BIOS, and then the computer restarts.
  10. After the computer restarts, the screen should display the HP logo.
Hope it helps!
Aug 11, 2014 | HP Touch Smart Desktop Computer "brand...
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
I press my power button and the fan starts for a second and blue disk drive light flashes like it is loading but nothing comes up on the screen and it will shut off about -5 seconds after pressing the...
have a look on the bottom of the case for access panels, remove these and check the fans for dust build up, even if the dust doesn't look too bad, its worth cleaning. Also try to remove the fan to check between that and the heatsink, dust can build up there very much. This could cause the fan to be innefficient so could be an overheating problem causing your shutdown.
May 06, 2011 | Dell Vostro 2510 Laptop
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Wont come on!
Starting with the easy stuff: Try plugging in the power cord, but not the battery.
If that works, your battery is either dead, or the circuit for it is shorted out.
Are there any signs of life? When you press the power button, do you hear any fans? do see any lights?
Does the screen flicker? Your RAM may be dead if it does.
Oct 05, 2008 | Acer Aspire 5315 Notebook
HP Pavillion dv9720us Notebook PC will not come on
i got mine fixed at r-tech for 160 dollars, they fixed my motherboard (818) 347-1100
Jun 25, 2008 | HP Pavilion dv9000z Notebook
Compaq Presario CQ50-215NR Notebook Logo
547 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
