Question about Sharp AL 1631 Copier
Paper will not feed and yet there is no paper jam that I can see. It just stopped feeding paper one day.
  • rosspalazzol Jun 07, 2010
    I really could not find anything wrong. I did separate the paper and made sure a clean sheet was on top for feeding and it seems to be working now.
    Thanks,
  • 6,487 Answers
This are the common things that you need to check to identify what is really causing the problem and to solve it from there.
1. The paper in tray could be damaged
2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
4. Feed tires are worn or dirty
Posted on Jun 07, 2010
Canon k420 copier
In some cases, not all; the paper feed rollers get dry and slick. If so they tend to feed at times and sometimes stop halfway at times. Look at your rollers.
Jan 17, 2014 | Computers & Internet
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Paper feed on my Konica 7020 is jamming can you help?
It depends on where it is jammng, if it is in the feed area change paper or clean the feed rollers above the paper tray. If it is crunching the paper look to see what is stopping it and correct it. If it still jams in the machine you need a tech to see why.
Mar 23, 2010 | Office Equipment & Supplies
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
Paper Jams
Depends where the paper is stopping. The fact it is feeding suggests that a sensor isn't stuck, most likely worn out feed, pickup and seperation rollers.
Aug 31, 2007 | Canon NP 6545 Copier
Sharp AL 1631 Copier Logo
51 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
