Question about Roper Washing Machines
My washing machine will not hold water and i dont know where the water is going
    President:
  • 949 Answers
When you say will not hold water, do you mean it keeps filling and filling and does not get full or overflow?
If so then you have siphoning going on. Typically it is caused if the drain hose from the machine is either too low or the hose is pushed too far into the house drain pipe.
Look behind the washer, the largest hose of the 3 back there is the drain hose. This hose should 'rise' up to at least the height of the washer tub before going down, what I mean by that is if the hose is just laying down or going to a drain that is lower than the tub, the water will siphon out of the tub.
If this drain hose is pushed into a pipe behind the washer it should only go into that pipe about 6", if it is pushed in too far it will also siphon.
See this link for more information and be sure to ask me questions if you do not understand or if I have misunderstood the problem.
Thanks
Wont stop filling washer
Posted on Jun 03, 2010
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
Apr 08, 2013 | Blomberg WM87120 24" Front-Load Washer...
My Whirlpool Ultimate Care II is not working properly
its is proberly the cold water vavle open circiut what happends is that if you where doing a normal load when this happend first time the computer in the machine will have stuck on that wash cycle and by putting it on a cold wash it will still fill up with hot water but dont worry if the cold vavle is replaced it will finnish the wash that it started (if this makes sence the cycle that you 1st selected might have been a low temp wash so the hot and cold will both come in together then it censes that the water is to hot so it switches the hot water valve off and the cold will stay on untill the machine fills to the crrect level and the machine carries on and complets that wash ( but because the cold valve is faulty it cant complet the only way to be sure that it is the cold valve valve is to take off the top off the machine and you will see where your cold water pipe connects thats the cold water valve usualy two valves together with 4 wires make sure you are switched off at the plug now swap the wires over on the two valves 2/&/2 one vavle is the rinse & main fill the other is the fab conditioner dont touch the hot valve wires and then what should happen is the machine will go though a complete wash but put it on the wash you started with so it can go though that wash the only thing that by doing this is that it will not take in the fab conditioner (i say it wont but it will because you swopped the wires over its going to fill the fab conditioner compartment and not the rinse compartment so swop the hoses on the valves also they will just pull off at leised you will know that is what your problem is the cold water valve is at fault. when you get the new valves dont forget to switch every thing back to how it should be ie change wires and hoses the machine may stop before spin because you have swoped the wires so dont worry it may not it is the easyest way for me to tell you how to test what i believe to be the problem you can get a set of water valves on line just type in www.espares.co.uk washing machines put in your make model no and water valves or water soliniods and you will find them it will give you the price before you buy anymore help let me know
Nov 25, 2011 | Washing Machines
My washer will not fill with water nor will it agitate , but it will spin out. also i dont know where the or which trap to check.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 16, 2011 | Whirlpool Washing Machines
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Sep 13, 2009 | Washing Machines
My washing machine wont stop filling with water
sounds like the hot cold water valve is bad,you also have the water level switch,the switch has a water level hose on it,some times the hose comes loose,chech y=that also,let me know what you find-mike
Mar 17, 2009 | Kenmore Washing Machines
Water in Drum
replace fill valve under top left rear its bleeding throw it will fix that
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
LG WFT7030TP
Trouble shooting a washing machine is easy but you have to know the sistem first if the washine machine take water wwell but dont do nothing eals could be a couple of things. The water level switch send curent to the water selenoids when the maching is empty then when the level of water reach the selected level the presure of the water active a presure swithc and the curent go to the timer there the timer send the curent to the motor, as you can see there are a procedure that you have to know to repair a washin machine and some instrument to trace continuity and curent warning disconect the machine frome ac outlet befor service .....good luck and rate me if you survive this riskey adventure...
Feb 17, 2008 | Washing Machines
Washing Machines Logo
104 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
