Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
My screen went out and im trying to find out what the problem is my sound still works and the tv cuts off after a few seonds of being on?? whats could this b?
    Scholar:
  • 121 Answers
Either your backlight circuit or image processor is shorted/fried, which would cause too much power across the circuits, causing it to shut off as a safety precaution.
Posted on Jun 03, 2010
After changing the display settings to a seond monitor , it now shows the computer screen on the tv but it does not show any icons or any thing im doing on the internet why ?
Right click on the desktop, choose Screen Resolution ans click Detect and Identify - you should then be able to choose the appropriate display and choose the Multiple display settings as required from the drop down list
Apr 11, 2012 | Computers & Internet
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
PS3 screen flash / sound cut-out
The PS3 has an issue with what's called the "HDMI handshake" between the PS3 and the TV. The PS3 does not even realise that this is happening. What you might try to do is turn the system on, play a game, and when the flashing and no sound occurs, unplug the HDMI cable from your PS3, wait a few seconds and plug it back in. This may resolve your issue. If it doesn't work, try component cables, there is no known issue with this problem occuring with this type of connection. Good luck!
Aug 20, 2009 | Video Game Consoles & Games
Picture went off on rca flat screen while watching still have sou
That probably happened because something hit the TV and broke the line for pictures to get through, or because a wire in you TV is bad and doesn't wanna work. This happened to my TV every few days. What I did is give it a few whacks every now and then on top of it and the vision came back, but don't try that if you think your TV is fragile. Yes I know its sounds stereotypical but it actually sometimes works.
Well, good luck!
Jun 04, 2009 | RCA TruFlat 27F520T 27" TV
Im on the tv, the screen shut down few minitues.
It sounds like the tv went out and needs to be repaired. Common causes are a bad power supply, circuit board, or power control board.
May 14, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Mitsubishi 56 inch dlp,screen says tv will turn off in a few seonds,air flow seems to be blocked,tv turns off and orange light comes on???? Have to push reset button to clear orange light,this is constant...
Hello!! It might be either that the tv is overheating because of the lack of air, or it may also be your ballast.
First of all I recommend you clean the fans, so the air flow won't be blocked, don't use something that mioght damage some of the boards that are inside, you can buy one of those air cans to clean computers, if that does not work, I recommend you listen closely and notice if there's a clicking sound, if so it might be the ballast.
Mar 14, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Black screen on tv but still have sound!
i used to work on the warantee's for relysis from memory that was a deffo dead un we used to swap out on that fault im pretty certain its a dead processing board . . . sadly relysis uk went bust . . . .
Jan 17, 2009 | RCA F32450 32" TV
Black screen sound ok
Have you tried unplugging the power for a few seconds and plugging it back in?
Aug 28, 2008 | Proscan 19LA25Q 19 in. LCD Television
Philips 27PT6441/37
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
May 03, 2008 | Philips 27PT6441 27" TV
RCA D61W20 Image Turns on and Off, Rat Droppings
im sure that the rodent contamination is the root cause of your problem. but the blueish stain does it look like a smear? if you that is most likely a phosphur burn in the face if the CRT. it cannot be fixed without replacing the CRT. i suggest living with it or putting tv on the side of the curb.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
