Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
My D40 Camera is not working. The lens are not detected. When I switched on my camera The aperture is not displayed. The display shows "F---". Please suggest me. We have already cleaned the Body and lens contacts. Thank you.
    Novelist:
  • 178 Answers
Very nice camera that is! when you send this in for repair, contact them, they will most likely want you to send in your lens with it to be able to diagnose correctly. the problem could lie in a couple of different things.
http://www.teleplancamerarepair.com/manufacturer/repair-camera-model-problems.asp?mo=93
Posted on Jun 03, 2010
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I am having a nikon D80 camera. In the display it shows Error. I i click the camera no focus,no picture in the memory card.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Jul 31, 2009 | Nikon D80 Digital Camera with 18-70mm Lens
Camera goes straight to F2000 and displays a white screen
Can you adjust aperture in manual mode?
If no, then aperture drive is jammed/broken in the lens.
If yes but it doesn't change anything, then CCD can't process light correctly and needs replacement.
Apr 02, 2009 | Fuji FinePix S5000 Digital Camera
Nikon D40
Try pressing the "info" button on the top of the camera next to the shutter button. This turns the LCD off and on to save battery life.
Jul 08, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Faulty nikon d40
That may be the best advice :
http://nikon.com/
Jun 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Error message on D40
The guy at the camera store is probably right. The aperture is controlled by a small leg that juts out from the lens mount. This leg/lever moves up and down to open the aperture. It could be stuck or broken. Try holding the lens (small end pointing towards your face) and peer into the lens as if you were taking a picture. Find the aperture guide (a small rectangular lever) and slide it up and down. You should see the aperture blades open and close. If they do, the camera is malfunctioning and in need of repair (warranty?).
Jan 17, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens stops functioning
Have you tried this same lens with other cameras? Do you have another camera body you can try? or perhaps a friend with a Canon EOS Camera? Also try the following please: Remove the lens. Look at the lens mount contacts, take a Cotton swap with some rubbing Alchol & clean the contacts very well, both on the lens and the camera body. Is your camera reading the lens aperture range correctly (at least most of the time)? Also since you replaced the PCB on the lens, isn't it under warranty? Let me know if this works. Thank you, AJ.
May 23, 2007 | Canon Zoom Telephoto EF 100-400mm...
What does the fEE error message displayed on an SLR camera mean?
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
"00" Apparture
If an aperture of "00" is displayed on the camera's LCD panel, perform the following steps in order. Check after each step to see if the problem remains, and proceed to the next step if it does. (In some cases, you may see "Err 01" displayed on the LCD panel.) 1. Check if the lens is correctly mounted on the camera. If no lens is attached to the camera, "00" will be displayed for the aperture value. 2. Clean the lens contacts. Turn the camera's power switch to OFF, and then detach the lens from the camera to clean the contacts. Use a blower to blow away dust on the lens. Do not touch both the camera's or lens' electrical contacts with your fingers while cleaning the lens. Turn the power switch to ON again and check the aperture value displayed on the LCD panel. Refer to the Instruction Manual provided with your camera for instructions for detaching or mounting the lens. Also, prevent any foreign materials or dust from getting into the camera through the lens mount, and be sure not to damage the contacts. 3. Remove the battery pack. Turn the camera's power switch to OFF and remove the battery pack. Then reinsert the battery pack, and then turn the power switch to ON again.
Aug 29, 2005 | Canon EOS-1D Mark II Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
79 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
