Question about RCA R52WM24 52" HDTV Projection Television
WORDS & picture not align - RCA R52WM24 52" HDTV Projection Television
  • Doug
    Doug Jun 03, 2010
    I'm not sure what your issue is.
  • RCA Master
  • 8,617 Answers
Replace the deflection board. You can get the ITC222A deflection board from www.tvrepairworld.com
Posted on Jun 04, 2010
Can you change directions on the letters? Up and down?
Assuming you are talking about MS Office....
  • Right click on the word or cell.
  • Select Format text/cell & look for alignment.
  • change the direction.
You can also change the vertical/horizontal alignment.
Jun 26, 2017 | The Computers & Internet
What is the positionof the cams for 2001 xlc 1200 before you instal the cover
This is one of the cases where a picture is worth a thousand words. If you'll contact me off forum, I'll scan in a picture and send it to you. Remind me of what you need. wd4ity@bellsouth.net
The cams are numbered, 1,2,3,& 4. The go in the engine case starting from the rear, 1, going to the front 4. All the timing marks between the cams must be aligned as well as the mark on the #2 cam must be aligned with the mark on the pinion gear.
Good luck
steve
Sep 25, 2010 | 2001 Harley Davidson XL 1200 C Sportster...
Timing belt marks for geo 1.3
From the book
crankshaft sprocket has a slot which must align with the key in the crankshaft
The mark on the lower timming belt sprocket must align with the mark on the engine front cover.
Pictures worth a bunch of words (email).
Feb 14, 2010 | 1996 Geo Metro
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Convergence amp
You usually have to replace the two ICs at the same time along with resistors to get the longest life from the Convergence amps. You can get the repair kit for your model at the following link which contains both ICs and all 6 resistors plus instructions with pictures that explain how to do the repair yourself. Heres a link to the correct kit for your model Toshiba.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
May 18, 2009 | Televison & Video
Cannot align dell 926 printer
I cannot get the alignment to work right it says Alignment problem I have done everything it says to do.
Mar 24, 2009 | Dell 926 All-In-One InkJet Printer
I have a Hitachi 50EX01BA big screen tv that will not align correctly. Picture is o.k but all the words are double. I tried to fix the alignment but it actually looks worse if the red & blue are put...
the convergence Ics you can get replacement ics at the following link and they will give free instalation instructions with pics so you can do the repair yourself.Heres the link.
May 02, 2008 | Televison & Video
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
Arches of words and top and bottom doubled with red words
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Oct 31, 2007 | Philips 60PP9202 60" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
