Question about Toro Lawn Mower With Toro Power Tools
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it manual..? Model # 20624
  • 29 Answers
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Posted on Jun 04, 2010
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Mower starts and runs but has no power acts like its flooding it burns a lot more gas can barley pull it self
Sounds like maybe the choke is stuck closed. If you remove the air filter the choke is the first butterfly valve you can see. The throttle looks similar but is a inch or so deeper into the carb, and you can't see that unless the choke is open. Try removing the air filter and starting the mower. It might run just a little better without the air filter since it will get a bit more air, but if the choke is stuck it still won't run right. But you will be able to see if that's the problem right off. If it runs great without the air filter, and the choke is not stuck, then the problem is a clogged air filter and you need to replace it. Good luck, Al K
Jul 26, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
I have a toro self propell it will start right up but after about
Blocking the breather is the same as putting the choke on. Check to see if you have a fuel line that is sucking air. A loose or cracked fuel Line.
Oct 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
My Toro self perpelled lawn mower starts then conks out.
It sounds like your fuel system is plugged up (or water in the carb) First i would make sure there is good fuel supply to the carb, then if so & not running, I would remove the carb and clean as it appears that it is running properly otherwise. Also check your air cleaner element as it may be totally plugged up.. Hope this helps you, Rick
Apr 26, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
295 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
