Master
- Posted on Jun 03, 2010
Re: How to change a tail light bulb on 2008 malibu? Not...
Step 1
Determine how the bulb is accessed: On some models the lens
(the red or white plastic part over the light) must be unscrewed from
the outside, and on others the bulb is accessible only from inside the
trunk. If there are no screws on the lens, you can assume that the bulb
must be replaced from inside. Usually there will be a plastic cover that
must be removed in order to access the bulb. There may be tabs, screws
or small knobs that hold this plastic cover in place.
Step 2
jQuery(document).ready(function(){
jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.2-800X800.jpg');
Unscrew the lens on the outside, or take off the plastic
cover from inside the trunk, to reveal the bulb.
Step 3
jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.3-800X800.jpg');
Unscrew the bulb. You'll have to push in and turn at the same
time.
Step 4
Take the bulb with you to the auto supply store to help you
find an exact duplicate.
Step 5
jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.5-800X800.jpg');
Clean the connection with a wire brush and/or wipe it clean
with a rag if there's any corrosion.
Step 6
how to change a tail light bulb on 2008 malibu? - replace-tail-brake-1.6-120x120.jpges/a00/02/i7/replace-tail-brake-1.6-800X800.jpg">
jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.6-800X800.jpg');
Screw the new bulb into the empty socket. Again, you'll have
to push in and turn simultaneously. Line up the tiny raised bumps on the
base of the bulb in order to screw it in.
Step 7
Replace the lens or the plastic cover.
Step how to change a tail light bulb on 2008 malibu? - replace-tail-brake-1.8-120x120.jpgspan>
jQuery('#jsArticleStep8 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.8-800X800.jpg');
Test your work by stepping on the brakes and turning on the
headlights while a friend watches the new bulb to make sure it lights
up.
